Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-26-2006, 08:52 PM   #16
355smallblock
Banned
Re: 96 neon (service engine soon)
Cant Set Timing At All.cant Reset 2 Trip Global Codes By Disconnecting Battery.the American Goverment Mandated That In 96.i Do This Shit Everyday Of My Life Cant Figure Out Why People Are So Hard Headed On This Site
355smallblock is offline   Reply With Quote
Old 09-26-2006, 08:55 PM   #17
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Noone is talking about setting timing and yes you can reset the PCM by disconnecting the negative terminal. When I have a code pop up and fix the problem, I disconnect and the CEL is gone. If the problem is still there, then the CEL will come back on.
2003 Dodge SRT-4
das2123 is offline   Reply With Quote
Old 09-27-2006, 10:29 AM   #18
Nikki2829
im still getting code 34 and i just replaced my speed sensor that i was told was the problem but i guess not...... do u have any ideas now what is wrong......light is still on and no speedomoter
Nikki2829 is offline   Reply With Quote
Old 09-27-2006, 10:38 AM   #19
das2123
Did you reset the PCM? Did you take care of the other problems as well? Try this for the speedometer problem.
Do you have an auto or manual?
2003 Dodge SRT-4
Old 03-05-2016, 03:54 AM   #20
Dr Dad
Hi, My daughter just gave back the Neon I gave her. 100,000 km in 4 years with no maintenance... Not bad eh? To tell you the truth I have changed the oil and filter around 4 times for her during this time. It is an auto and the check engine soon lamp is on. Surprise surprise!! I have changed oil, filter fuel filter, leads, air filter, plugs, but still lamp is on. I will check for codes tomorrow. This is a very handy website. I am pleased I found it. Also no reverse when the engine is started from cold. After about 45 seconds to 1 minute of idling the car jumps and bangs into reverse. Do you think this could be due to no auto trans fluid change in at least 4 years or 100,000 km? I am wondering if it is worth wile changing the trans fluid or just counting my losses and taking it to the wrecking yard. What do you think?
Dr Dad is offline   Reply With Quote
Old 03-05-2016, 03:59 AM   #21
Dr Dad
Hi, I know it was quite a few years back, but did you ever get to the bottom of why the check engine lamp was on and did it eventually disappear? I am having the same problem with my daughters Neon.
Old 03-05-2016, 03:20 PM   #22
das2123
I'd check the coded first and then report back. If it's never had a fluid and filter flush for the tranny, it's probably worth the $100 investment.
2003 Dodge SRT-4
