| Latest | 0 Rplys |
05-09-2007, 08:52 AM | #1 | |
'94 tranny drip leads to thermostat prob.
After attempting to tighten the lower tranny fluid line to my radiator my car overheated due to a loose hose clamp on a water line. from this tightning of the tranny line. I corrected the coolant leak. 15 hrs later (car shut off) my temp gauge still reads 240º. So the question is: is the gauge stuck or what? it is the first time i have overheated it, I do not wanna tear out my dash to replace the gauge. Anyone have a clue?
05-09-2007, 11:52 AM | #2 | ||
Re: '94 tranny drip leads to thermostat prob.
i stopped at a garage since, i was told my coolant was low 5qts. i guess you have to have the engine running to fill the coolant. The mechanics prognosis on the 280º temp was : faulty gauge. now i wonder if drilling a eenccy weency hole in the clear face, and nudging the needle will help??? the 5 qts of water, free of charge |
05-16-2007, 11:52 PM | #3 | |
In Canada we have to mix antifreeze 60 glycol 40 water because of the low temps. We also have hot summers. The Glycol has a higher boiling point. Too much water will cause boil overs.
I assume your gauge is electrical. Find the sensor and pull the connector off. Apply 12v to the positive lead giving it a burst or two. Check the gauge. If you have two wires leading to the sensor, then try reversing polarity momentarily. You may find it winding the guage back to a normal position. Cheers |
