Go Back   Automotive Forums .com Car Chat > Panoz > GTRA / GTWS / GTS
Old 02-09-2013, 09:31 PM   #1
Cobra4B
Cobra4B's Avatar
Passenger side fuel line shield? On all cars? Needed?
What's the purpose of this piece? On the GTRA there were originally two fuel lines (one for the return) and the main electrical cables. Now that I'm redoing the car I have no need to put the return line back in place (carb) and the main electrical cables are being run inside the cabin down the passenger side like the GTSs. At this point do I need this entire piece? Is it a debris shield or a heat shield or both? Can I Just put some wire loom or other protectant on the fuel line and forgo installing this shield?
Thanks,
Brian
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Cobra4B is offline   Reply With Quote
Old 02-12-2013, 11:49 AM   #2
Cobra4B
Cobra4B's Avatar
Re: Passenger side fuel line shield? On all cars? Needed?
Anyone?
Brian B.
Old 02-12-2013, 06:17 PM   #3
gamacdon
my car does not have one and i do not think it ever did
gamacdon is offline   Reply With Quote
The Following User Says Thank You to gamacdon For This Useful Post:
Cobra4B (02-12-2013)
Old 02-12-2013, 07:24 PM   #4
Cobra4B
Cobra4B's Avatar
Do you have anything protecting the fuel line? Here's the response I got from Panoz today.
That part was just a debris/heat shield used only on the GTRA's. It is not necessary, though if memory serves, the fuel line is aluminum so it does need some sheathing to protect it. We did relocate the fuel line to the passenger compartment in the GTS cars.
Brian B.
Old 02-12-2013, 07:42 PM   #5
gamacdon
yes, mine has a sheath/cover running the whole length. it looks like an insulation material you would find on an HVAC copper tube.
Cobra4B (02-13-2013)
Old 02-13-2013, 08:27 AM   #6
Cobra4B
Cobra4B's Avatar
Ohhh... good idea. Better than what I had in mind and easy to get at the hardware store. This stuff?
Brian B.
Old 02-14-2013, 11:53 PM   #7
NZGTRA17
Brian, I have 2 x 3" exhausts running into the cavity on the RH side between the chassis and the NASCAR intrusion bars. The whole cavity is stuffed full of mufflers and bloody hot pipes.
I have just used the Panoz fuel line wrap and added some additional heat shield material between the pipes/mufflers and fuel line and it has been fine so far.
Kel.
Kel M
Panoz GTRA #17
New Zealand
NZGTRA17 is offline   Reply With Quote
The Following User Says Thank You to NZGTRA17 For This Useful Post:
Cobra4B (02-15-2013)
