| Latest | 0 Rplys |
09-20-2005, 12:11 AM | #16 | |
i'm betting on PROBABLE tuneup problem not maf --ie bad wires, plugs----maf is not generally known for popping exhaust---one thing you learn and learn well when you are a young mechanic(that was quite a while ago) any internal combustion engine that has a misfire under load(shaking/shimmy on acceleration, popping/backfire) is 99% of the time is due to secondary ignition failure---and yes it sometimes is that easy----computers tend to complicate the thought process not the diagnosis or repair
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING. |
09-23-2005, 05:53 PM | #17 | |
mass air flow sensor
I am also having problems like this. My 94 tbird 4.6 runs like crap when you first start it. If I give it gas the car sounds like it wants to die. After the car warms up it runs fine. I did have my computer replaced two years ago, and I also have a K&N filtercharger. One of you gents suggested carb cleaner, did anyone try it. I am somewhat ignorant on how to work on vehicles, but I changed my TRS and cleaned the throttle body, and the problem still persists. Any other ideas on what the problem, and resolution may be?
09-23-2005, 11:12 PM | #18 | |
forza your problem sounds more like maf as it is very temp sensitive and symptoms get progressively worse over time--i cant remember what thread it was in but i gave a detailed explanation of operation and why its bad when cold and is fine when at operating temp--look back thru files
09-24-2005, 11:54 AM | #19 | |
PROBLEM SOLVED!
i finally found a tamper-proof torx bit set and i removed my MAFS and there it was, plain as day- corrosion. i bought a special electrical cleaner spray and soaked everything in sight. i scrubed the corrosion with a toothbrush and wiped it all away. i put the sensor back on and i noticed an IMMEDIATE difference. my car never drove so well. thank you all for you help, i love you!! |
09-25-2005, 10:40 AM | #20 | ||
Re: mass air flow sensor problem maybe
89 SC coupe |
01-10-2006, 01:17 PM | #21 | |
i to have a 95 tbird 4.6 and had the same problem i had the codes checked and replaced the mass air flow sensor replaced but it didnt fix the problem. so i took it to a shop and the took out the computer cleaned it up and it ran like new
05-21-2006, 11:16 PM | #22 | |
I was wondering about how much did it cost to take it to the shop and have the computer cleaned up, I think I might have the same problem. I started the car and it was fine but after I warmed it up I started driving and it turned off. I turned it back on and it ran fine again, but after a few blocks its started loosing power and I tried accelerating, but the car was hesitating. I turned it off and then back on and I left it in part for about 5 minutes and then I put it in drive and it was fine until 30 minutes later when I turned it off and I tried it again.
thanks for your help
1991 5.0 Tbird LX 1992 3.8 SC Tbird 1994 4.6 Tbird LX 1993 1.8 Eagle Talon DL |
05-22-2006, 07:07 AM | #23 | |
When I needed to clean my MAFS, I didn't have those symptoms. My car would run sluggish and hesitate when I accelerated, but it would never shut off on me. Maybe check your accelerator or the 15A fuse powering it? But either way, I never brought it anywhere to clean it, I did it myself. I had to get a tamper proof torx bit set (the star with the circle in it) to take the MAFS off. Then I soaked it with a special $5 electrical cleaner spray that I got at a Pep Boys or AutoZone. When I put it back together, it ran just fine. Whatever problem you have, good luck fixing it!
Paul |
05-28-2006, 03:48 AM | #24 | |
Thanks for the info. I will try checking the fuse if that doesn't solve it then I will try to clean the mafs.
thanks
05-29-2006, 02:27 AM | #25 | |
Clean the computer? Ok thats a new one to me.
I love these new computers heck they are what put the bread on the table here! hahahahah sorry your pain is what keep my dad in buisness.
A founding member of HNF car club! Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide! Racing a Honda is like being in the special olympics even if you win your still retarded! |
