Go Back   Automotive Forums .com Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 10-25-2004, 11:01 AM   #1
Jungleman
Angry Black smoke from exhaust
I need to know what i can do to stoop the black smke from coming out of my tail pipe, this has reduced my gpm badly, i also want to know where i can get a new brain box for my isuzu trooper 94 (SOHC, IEFI)
Jungleman is offline   Reply With Quote
Old 10-25-2004, 12:22 PM   #2
95.5 Rodeo
95.5 Rodeo's Avatar
Do you have the Isuzu 3.2L engine installed like I do? The Oxygen sensor was causing the black smoke in my Rodeo.
http://www.automotiveforums.com/vbul...d.php?t=258045
I'd check the oxygen sensor and other inputs to the ECM ("Brain box") before replacing it. The ECM is expensive and not likely to be the source of your problem.
Is the check engine lamp lighting up on your Trooper?
Dale
95.5 Rodeo is offline   Reply With Quote
Old 10-26-2004, 03:26 AM   #3
Jungleman
Re: Black smoke from exhaust
I diagonised the original ECM in the car, it did not give any errors, I tried another ECM, but the car could not drive, it was showing "check transmission". but when i replaced the ECM back to the original one it stopped smoking considerably, but them the MPG is still bad. Also my engine oil was loosing viscousity. I still would like to know how much an ECM for this would cost?
Old 10-29-2004, 06:01 AM   #4
Jungleman
Heeeeeeeeeeeelllllppppppppppp
I need to know what to do
the smoke is killing me
Old 10-29-2004, 08:31 AM   #5
amigo-2k
Isuzu Guy
you can buy a used ecm at www.car-parts.com
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
amigo-2k is offline   Reply With Quote
Old 10-29-2004, 09:33 AM   #6
travelman
I agree with the change the O2 sensor advice. Computer boxes very, very, very rarely fail out of the blue. Now if you had spilled a soda on the box or shorted a wire and then had a problem I can see the computer as being a likely culprit.
02 sensors on the otherhand can yield exactly your symptoms. They, and their electrical connections, routinely fail because of the harsh environment they are in.
travelman is offline   Reply With Quote
Old 10-29-2004, 11:05 AM   #7
Jungleman
Travelman,
If the O2 sensor is bad it would show up when you run a diagnistic on th ECU right, but them i dont get any errors from the sensors. How can i find out if the O2 sensor is bad?
Old 10-29-2004, 11:37 AM   #8
95.5 Rodeo
95.5 Rodeo's Avatar
When my oxygen sensor went bad, the check engine lamp did not light up and there were no codes stored. You need a scan tool or a scope to test the oxygen sensor.
I believe the replacement interval for the oxygen sensor is every 60,000 miles (96,500KM).
If your Trooper has more than 60,000 miles, change the oxygen sensor. It is much less expensive than the ECM, which rarely fails.
Does your engine oil have a very strong smell of gasoline? If it does, that would explain why the oil is losing viscosity. The oil is saturated with gas from running too rich all of the time.
Again, what size engine do you have in your Trooper?
Dale
Old 10-29-2004, 12:04 PM   #9
Jungleman
Dale,
Thanks a lot, i have a 3.2L engine, is the O2 sensor different from the ones you find in honda cars cos i have spares for my honda 88.
Rgds
jungleman
Old 10-29-2004, 02:03 PM   #10
95.5 Rodeo
95.5 Rodeo's Avatar
If it were me, I'd only replace it with a Bosch oxygen sensor manufactured for my vehicle.
On the other hand, if I were in the jungles of Nigeria, with no auto parts store within 100 miles, I might try one from the Honda.
Provided-
You have a new or gently used sensor from the Honda.
It is a 4 wire oxygen sensor. If the Honda sensor is a 1 or 2 wire, I'm sure the Trooper's ECM will toss a code at you.
You will have to rewire it to your connector. You will need to know what the 4 wires on the Trooper connector do and what the 4 wires on the Honda sensor do. It is very important that you wire this correctly or you will make more problems for yourself.
It screws into the hole in the exhaust.
How many miles do you have on that Trooper? Does the oil smell like gas?
Just curious, how much does it cost to buy gasoline in Nigeria?
Dale
Old 11-02-2004, 09:50 AM   #11
Jungleman
Dale
My car has over 150,000miles, it is a 3.2L, I brought out the O2 sensor and had it cleaned, the smoke comes intermittently now, but not as bad though. When i take of the ECM fuse it stops smoking for a while the starts to smoke again.
My fuel consumtion is like 7 miles a barell (In Nigeria we buy at $1.5 a barrel) that seems bad to me. What is do you think is the normal consumption for my engine?
Jungleman
Old 11-02-2004, 11:14 AM   #12
95.5 Rodeo
95.5 Rodeo's Avatar
Jungleman,
If I were you, I would install a new Isuzu or Bosch oxygen sensor. The sensor is not something that can be cleaned and made like new. When they wear out, you must replace them. The money you save in gasoline will eventually pay for the sensor's replacement. Be sure to pull the ECM fuse for 15 minutes after installing the new oxygen sensor. This will reset the ECM back to the leaner factory setting.
That is what is happening when you pull the ECM fuse. The computer will run the engine lean at first until the bad oxygen sensor tells it to richen up.
You mentioned your oil is losing viscosity. Does your oil smell like gasoline? If so, I would change the oil and filter especially if you have driven your car a lot while it is blowing black smoke. The unburned gasoline has to go somewhere and that somewhere is out your tailpipe and into your oil pan. Be sure to do this, the unburned gasoline is washing the oil out of your cylinders, causing increased wear.
I get 14 miles per gallon in winter and about 16+ in the summer. This is all city driving. I don't know how to convert miles per gallon into miles per barrel.
Is a barrel about a liter?
Good Luck,
Dale
Old 11-02-2004, 11:18 AM   #13
Jungleman
Dale,
Thanks a lot, i will make arrangments to get another O2 sensor.
Rgds
Obinna
Old 11-02-2004, 11:34 AM   #14
95.5 Rodeo
95.5 Rodeo's Avatar
You are welcome.
Let us know how things work out for you.
Dale
Old 11-24-2004, 03:53 AM   #15
Jungleman
Guys,
I was able to get a brand new O2 sensor and it worked quite well.
my MPG went up but somehow it is not as good as the initial time.
I noticed that the engine gets sluggish once i start to move after
starting, sometimes it even stalls, but it does not repeat again.
ai would like to know why i get such sluggish response from the car. Also the RPM goes high (2600) before changing to the next
gear. This does not seem normal. any ideas from you guys?
Rgds
Jungleman
