06-20-2004, 12:44 AM | #1 | |
ignition switch
I would appreciate it if someone can tell me how to remove the ignition switch on my son's 1990 Ranger. Is there a pin to push or something along those lines. it's late, I don't have a manual but have remove switches befor ebut can't seem to figure this one out.
Thanks in advance |
06-20-2004, 07:49 AM | #2 | |
Re: ignition switch
I think you talking about key cyl if this is the case look under the cyl for a hole and turn the ign on, push the button, pull cyl ather wise you need to pull steering wheel and turn signal switch and you will see the button
06-20-2004, 08:54 AM | #3 | |
Yes it is the key cylinder I want to pull. There are no holes around the cylinder so it looks like I will be pulling the steering wheel.
Thanks |
