Go Back   Automotive Forums .com Car Chat > GMC > Acadia
Old 11-03-2013, 04:22 PM   #1
funtag
swap a engine 2012 ENCLAVE 07 ACADIA VIN 7 8th DIGT
Can I swap a engine from a 2012 ENCLAVE with VIN D 8TH DIGIT put in to my 07 ACADIA VIN 7 8th DIGT what can be dun? what's the difference can this be dun and if so what? please help. Thanks
funtag is offline   Reply With Quote
Old 10-27-2014, 09:43 PM   #2
jyount
Re: swap a engine 2012 ENCLAVE 07 ACADIA VIN 7 8th DIGT
That is a direct injected engine and yours wouldn't be. I would think there would be ECM, BCM, TCM etc problems unless you put your engines top end on it. Meaning heads and up. In short it wouldn't be worth the trouble IMO. What's wrong with it? Is fixing it out of the question? 13 hp and 19 ft-lbs aren't worth the trouble if you ask me. The 2009 got the DI, anything newer would have the same problem.
Yes I am aware this is a very old post. Doubtful it will help the OP, but maybe someone else...
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
jyount is offline   Reply With Quote
