| Latest | 0 Rplys |
03-08-2005, 08:32 PM | #16 | ||
Re: Re: Re: Re: starting problem fuel related
03-08-2005, 11:13 PM | #17 | |
I went through this with my 95 Blazer 4.3.
If the fuel pump gets worn (the inlet filter or sock split on mine and pieces of it were going into the pump) the pressure will drop and you will get starting. Mine was down to 42 and it would not start without starting spray. It should be about 50 which yours is. That should be supplying enough fuel. The "spider" or CPI uses nylon hose. It cracks with age and leaks fuel into the intake. The top of the intake actually comes off pretty easily. If you have standing fuel puddles the CPI needs to be changed. There is a connector piece, nylon line of course, that should be changed at the same time. Mine went bad shortly after the pump. With the leak you are not directing the fuel to all cyls. This is probably what's wrong with your car. Some intakes have a plug about 1 1/2" diameter that you can take off and look inside for fuel puddled. Don't run it with the cover open. If you do this yourself it may be worth it even on a vehicle with high miles. I'd check rockauto.com or gmpartsdirect.com for prices. Autozone may carry it now. I got a deal at that time and paid about $250 for the CPI and $50 for the connector. |
04-24-2005, 01:14 AM | #18 | |
try the ingition control module
09-18-2005, 01:01 PM | #19 | |
Try a crankshaft sensor. It's on the right side of the engine under the plastic plate that covers the oil filter.
Ray |
09-19-2005, 12:04 AM | #20 | |
AF - Advisor
It would be more info if you could check for plug firing and fuel pressure during the no start cranking.
The fuel pump runs for a few seconds after you turn the keyswitch on then the oil pressure has to be normal before it'll come back on....normally a coupla seconds after the motor starts. |
