| Latest | 0 Rplys |
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
09-20-2009, 10:27 PM | #1 | |
texas heat?
ive got an auto 91 300zx tt with jwt ecu and jet boosts and bolt ons and am having problems boosting 13.5 psi it does sometimes but not all the time it either runs 12 to 13.5 or barely 5 psi (more times it runs low boost) i dont have upgraded side mounts but should the heat make that big of a difference or is something else wrong? already considered boost leak but wanted to hear others thoughts as to what could be wrong..
92 240 sr20det bolt ons t28 stripped hatch (white knight) 91 300zx tt daily driver stillen exhaust, stillen down pipes jwt ecu, 18x10 rear 18x8.5 front adr wheels hks line controller etc.. |
01-13-2010, 08:17 PM | #2 | |
Re: texas heat?
Upgrade sidemounts will lower your temp and make the car run better at higger boost.. But, your problem isn't the SMIC. Part of your problem is the boost jets and most likely the way you've set them up..
I have a pair of Greedy SMIC for sale |
02-03-2010, 12:03 AM | #3 | ||
Re: texas heat?
My email is skaterboy1689@yahoo.com The problem with hitting 6psi, its caused by your ecu. Thats safety boost. run your ecu codes and it will tell you whats wrong.
GT2560r's, Nismo 615cc, ARP Head Studs, UD Pulley, SouthBend Stage5 clutch, 60mm TB's, Ash-spec Tune, Specialty Z 3" DPs, HKS intake, Energy Suspension, z1 Drive Shaft,E-fan, Port/Polished heads, AMS Manifolds, HKS SSQV BOVs, Howe Radiator, RPS segmented LW flywheel, UR OverDrive waterpump pulley, Billion Thermo, z1 silicone hoses, Stillen gauge pod w/autometers, D&S rotors all around |
