| Latest | 0 Rplys |
08-14-2012, 06:28 PM | #31 | |
Re: A new noise coming from engine compartment
WTF where did that last post come from? planetoffice? Darn spammers... Would somebody please delete it?
Anyway... I just got back from test driving it and NOPE, the noise did not go away. It's still there under the same circumstances. I'm back at square number 1; what would be the next step? I know I already asked, but since the LTFT1 is a bit rich, could it be an exhaust leak causing the noise? Thanks in advance, Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
08-14-2012, 07:36 PM | #32 | |
Hey scubacat, when the tensioner went in yours, was it wobbling?
How did you decided it was bad? Oscar.
08-16-2012, 11:52 AM | #33 | |
So I've been hunting for an oil pressure gauge tester but no store stocks it at the moment and autozone does not have it for rent, that really sucks... I asked a friend if I could borrow his but says it's broken, tell me about bad luck!
I'm kinda getting frustrated about this noise, it makes me really nervous to think that it might be a problem in the valve train, I'm not sure if I could deal with that in the tight space I have. Anybody thinks this could be a problem with a stuck/collapsed lifter? I'm also considering the idea of a bad water pump, there's been some rattling noise for some time now in the engine compartment, it also seems to come from the drive belt area; in fact I posted a video about it in the forum some time ago. I'll give it another try and see if this time I can spot where the noise is coming from with a screwdriver. Any other thoughts that I could try in the meantime? Oscar.
08-16-2012, 12:35 PM | #34 | |
A screwdriver sometimes works ... sometimes you need a semi-rigid plastic hose ... I borrow the hose from wife's small vacuum cleaner for this task.
The Following User Says Thank You to 12Ounce For This Useful Post: |
olopezm (08-16-2012)
08-16-2012, 05:14 PM | #35 | |
Well, just got back from driving "the nightmare"...
Drove all the way and back with my cheap scanner connected with moderate to heavy traffic and temperature never went above 192F with A/C on and 210 with A/C off. I even left it idling for a while and temp never went higher than that. That surely gives me peace of mind as I now know it's not overheating at all and water pump should be OK. Here's the IMPORTANT STUFF. I found where the noise is coming from; as soon as I got into the garage I noticed the noise, grabbed the screwdriver and started sticking it at every component within reaching distance... nothing. When I finally crawled under the engine I held the screwdriver against the OIL FILTER ADAPTER and surely THAT'S WHERE THE NOISE COMES FROM. Now I can say it's a CLICKING NOISE. I don't know what's causing it, but since the oil pump is rotating, it should make something more like a whining/grinding noise; oil pickup screen should cause some similar noise since the oil pump is starving. That leaves me with a noisy anti-drain back valve in the motorcraft oil filter. I certainly don't know what's causing it, I've never heard of one before. Maybe I just got a defective filter? Im guessing I should just replace it? Has anybody heard of a similar situation like mine?. Oscar.
08-16-2012, 06:06 PM | #36 | |
You should certainly try a new filter ... but the noise may be in the primary oil pump check valve/pressure relief valve ... which is built into the front cover. Quite an important little spring loaded affair. Its a wonder that it lasts so long normally.
I replaced the one in my '99 when I gave the engine a light over-all ... just to see what it looked like. |
08-16-2012, 06:29 PM | #37 | |
Thanks 12Ounce,
I'll replace the filter. I wonder how hard it was to replace the check valve and what's involved? I'm guessing the oil pump has to come off? Oscar.
08-16-2012, 06:55 PM | #38 | |
Oscar if the noise does not stop with a new oil filter, (what brand is on now Oscar) could it be possible that the camshaft syncronizer could be bad and the noise is transmitting thru oil pump to filter????
What is your thought oscar and 12Ounce? Just a thought. |
The Following User Says Thank You to tempfixit For This Useful Post: |
08-16-2012, 06:58 PM | #39 | |
Removing the timing cover is quite a chore on this beast. I really hope that's not your problem!
The Following User Says Thank You to scubacat For This Useful Post: |
08-16-2012, 07:40 PM | #40 | |||
The one currently installed is a Motorcraft filter, bought at the dealer. It's very funny because we've used crappy FRAM filters amongst others and never had a problem and this is the first time I ever use a motorcraft filter and BAM! ticking noise present... Scubacat, definitely you're not the only one with bad luck! I'm not totally sure but, if the synchro is the thing coming out from the block between the water pump tube and intake manifold, I held the screwdriver against it (thinking of your previous advise) and it doesn't makes any noise. In any case, a bad synchro would be better than the pressure relief valve . Quote:
***** Thank you guys! The noise seems more pronounced towards the oil filter rather than the adapter, so I'm confident a new filter should take care of the problem. I say it would be too much coincidence to replace the oil and filter, and the relief valve starts to fail; specially when it was working fine the day before and I don't think a different oil viscosity would cause it to fail, at least that's what I think but since I've not much experience I might be wrong. Oscar.
08-16-2012, 10:09 PM | #41 | |
Oscar harbor frieght has a oil pressure gauge that you could order online, they are fairly cheap.
http://www.harborfreight.com/engine-...kit-98949.html |
olopezm (08-17-2012)
08-16-2012, 11:05 PM | #42 | ||
The noise is more of a rattle but also has squeal undertones, it was extremely annoying.
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
The Following User Says Thank You to Windstartled For This Useful Post: |
08-16-2012, 11:06 PM | #43 | |
IIRC, the pressure relief valve is captured by the oil pump housing which is bolted against the front cover. In theory, the front cover does not have to be removed ... just the oil pump. But I'm not sure that removing the pressure relief valve is possible with the liimited work space ... it may be possible, but I had mine on the work bench.
Removing the entire front cover with the engine in place is indeed a task! I've done it but I would not wish it on anyone! |
08-17-2012, 06:33 PM | #44 | ||||
******* So, I installed a new filter and took it for a test drive but no, the noise did not go away; after some time (~40 minutes) the noise came back and, as before, it's only noticeable at idle and close to the oil filter adapter. Any other ideas guys?, I'm ready to set this thing on fire... Oscar.
08-17-2012, 08:25 PM | #45 | |
Ok, I've been reading some more and I'm thinking tempfixit's might be onto something with the bad synchro idea; Tempfixit, even when you actually mentioned it, I didn't know it was directly connected to the oil pump; that's why I didn't think it could be the problem.
I'll try searching more info, but would still like to ask what symptoms could a bad camshaft synchronizer cause? I've been noticing the engine will misfire from time to time at idle while in gear (I already cleaned IAC); engine died on me once while waiting at a red light without notice; I also get an occasional rattling noise that also goes away with RPM's, I kept tracing it but could only narrow it to the area around the PS and water pumps, synchro sits between both!. Could all/some of these be caused by the synchro? Oscar.
