Old 04-10-2008, 07:55 AM   #181
Nino Furicchio
Nino Furicchio's Avatar
Re: 935 turbo Martini (hundreds of machined parts)
Thanks friends for the comments, they are of help for me to go on in this "bet".
The dashboard almost completed,new warning lights has been machined at the lathe from 2,5 mm round bar (the thickness of each finished piece is 0,8 mm) than painted in transparent color.In my reference photos the boost controller is installed into the dashboard and not on the floor as in the SMS photo CD,so only the handle grip is visible,the piece was machined time ago and now is on. The internal cooling duct has been added after have drilled out a precise hole in the dashboard.
The ultimate Porsche thread?
http://www.automotiveforums.com/vbul...d.php?t=764148
Machining master
Nino Furicchio is offline   Reply With Quote
Old 04-11-2008, 11:26 AM   #182
Nino Furicchio
A new shift lever,with pin and linkage has been machined from aluminum bar,also the shift lever mount has been modified.
Machining master
Old 04-12-2008, 02:03 AM   #183
mrawl
mrawl's Avatar
Amazing as always. What a superb build...
Mark R
mrawl is offline   Reply With Quote
Old 04-12-2008, 11:43 AM   #184
Shovel
Shovel's Avatar
Every time I look at the new pic's of the piece you've machined I want to add a reply to this thread. Only problem, I first need to pick up my jaw from the table and I'm lost for words after fixing this.
Awesome job you are doing here Nino.
Look forward to the next update of this fantastic build.
Grtz,
Mark a.k.a. Shovel
Shovel is offline   Reply With Quote
Old 04-12-2008, 09:09 PM   #185
Big Kahuna
This is the one stop, how to machine everything for a model car thread!
Awesome work.
Big Kahuna is offline   Reply With Quote
Old 04-18-2008, 12:28 PM   #186
Nino Furicchio
Once more thanks for the comments.. Inside the work proceeds well,after the gear shift I have realized the system of regulation of the rear anti roll bar from scrach,part n°4 in the photo is the tower realized in styrene 0,3 mm,part n°1 the regulation lever and part n°2 the semi gear for regulation are completely machined at the lathe from aluminum bar.Part n°3 is a new cap for the water reservoir,it need a better painting.
Machining master
Old 04-18-2008, 12:39 PM   #187
Spike2933
Spike2933's Avatar
Send a message via Yahoo to Spike2933
so, when will it be ready to run, this build is a thing of beauty, keep it up
Steve
Spike2933 is offline   Reply With Quote
Old 04-18-2008, 02:24 PM   #188
Duncan1098
Duncan1098's Avatar
It is really looking supurb, I love the interior, the gear shift is amazing, as is the rest of the car. I will have to start my 934 sometime.
Duncan1098 is offline   Reply With Quote
Old 04-19-2008, 02:22 PM   #189
billypee
billypee's Avatar
Send a message via AIM to billypee
Awesome update Nino. Great attention to detail.
Bill
On the workbench:
Completed WIPs:
Completed Models Gallery:
billypee is offline   Reply With Quote
Old 04-20-2008, 10:43 AM   #190
isseychanel
真他妈牛逼。。。。。。。。。。。加油昂
别成了太监贴
isseychanel is offline   Reply With Quote
Old 04-28-2008, 03:15 PM   #191
Nino Furicchio
Thank you to all for looking (over 30,000 views for this thread is a great result for me!) and for the comments.
Other details of the inside,as the adjustable anti roll bar regulator finished. The long pipe for the intercoolers is made out from TIG welding aluminum bar .
Machining master
Old 04-29-2008, 04:52 AM   #192
Duncan1098
Duncan1098's Avatar
It certainly deserves all those views, it is one of the best builds I have ever seen
Old 04-29-2008, 11:53 AM   #193
Shovel
Shovel's Avatar
(I couldn't agree more)
Mark
Old 05-02-2008, 05:15 AM   #194
Nino Furicchio
Another view of the inside,the pipes for the water intercoolers finished.
Machining master
Old 05-03-2008, 09:23 AM   #195
Nino Furicchio
Also the pedals received detailing, I have decided to bring only light changes in this zone because few visible, using simple materials as small wires .
Machining master
