| Latest | 0 Rplys |
10-27-2005, 05:03 PM | #31 | |
Re: I have a solution.....to the CLUNK>>>>>
It is too big for the yoke, after a couple of weeks with half of the ball in mine, still no clunk.
10-27-2005, 06:05 PM | #32 | |
Is this problem only on 4wd models?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
10-28-2005, 08:03 AM | #33 | |
Mine is a 4 wheel drive
10-28-2005, 10:12 AM | #34 | ||
Re: Re: Re: I have a solution.....to the CLUNK>>>>>
10-28-2005, 10:19 AM | #35 | ||
Mine does it and its a 4wd.
99 Z71 00 Tahoe LT |
10-28-2005, 11:19 AM | #36 | ||
Re: Re: Re: Re: I have a solution.....to the CLUNK>>>>>
10-28-2005, 11:27 AM | #37 | |
So has anyone been able to stuff the whole ball in? I'm thinking of doing it this weekend, just want to know what to be prepared for.
11-01-2005, 07:45 PM | #38 | |
UPDATE: Well I did the lucas tranny treatment, it started to work a little better but I still had a clank once in awhile. Tried to stuff a ball in the yoke but gave up. Took into the dealer monday and they flashed the puter and found one up-grade. Haven't noticed the slip between 1-2 and the clang is gone but I did hear the clunk one time. All in all I'm a bit happier. Oh yeah they changed the steering shaft also.
11-02-2005, 08:27 PM | #39 | |
In response to my squawk and slip when pulling out from a dead stop, I finally broke down and took her to the dealer cause I was tired of trying to find Waldo with blindfolds on. Turns out the noise was from two places...
Slipyoke (which I DID lubricate), needed a specialer (yes it's my new word) type of lubricant then I used.. I had some rubbing of some sorts in the leaf springs so they added rubber insulators to them to keep from metal to metal grinding. $88 later and I'm quiet as can be. Now I just have to re-break down and dump the $130ish it's gonna take for them to put the replacement steering column unit in.
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16 K&N FIPK - Flowmaster 50 Series 3.5" Duals 4-Headlight Conversion Kit - Billet Grille 90 Watt Nova Strobe Pack 2.5% Limo Tint - Check Out Pictures and More Here http://www.cardomain.com/ride/2131569/1 |
01-08-2006, 01:37 PM | #40 | ||
It's been a couple months now, how's the 1/2 ball solution working? |
01-10-2006, 03:22 PM | #41 | ||
01-13-2006, 04:27 PM | #42 | |
Mine is still quite, I wish that I would have known about this 2 years ago.
01-13-2006, 05:02 PM | #43 | ||
01-14-2006, 10:59 AM | #44 | ||
01-14-2006, 02:13 PM | #45 | ||
Fire24, Put two scratches on each drive shaft so that you may realign them later. There is likely a Carrier bearing holding one of the shafts, don't remember which. Drop the back shaft at the Differential, pull the shaft out of the yoke. Don't damage the splines. Clean both spline and yoke. Grease with as much good grease as you can. I used slick50, there may be a better choice. I don't believe the Zerk fitting distributes the grease. Reassemble. Good luck. |
