03-12-2004, 10:30 AM | #1 | |
gm code site
here is a link for a gm site i found on the net hope it works for you www.wrenchman.freeservers.com/fordsux/gm.htm
03-14-2004, 04:03 PM | #2 | |
Main GM Guy
Re: gm code site
That will work for anything older than an 1995 car or truck that is OBD!
Here is an OBD2 list for all modules!!! Diagnostic Trouble Code (DTC) List - Vehicle DTC Descriptor DTC B0012, B0013, B0014, B0016, B0017, or B0018 Right Front/Passenger Frontal Deployment Loop (Stage 1) Circuit DTC B0022, B0024, B0026, B0042, B0043, or B0044 Left Front/Driver Frontal Deployment Loop (Stage 1) Circuit DTC B0028, B0029, or B0030 Right Front/Driver Side Deployment Loop Circuit DTC B0040, B0041, or B0045 Left Front/Driver Side Deployment Loop Circuit DTC B0051 Deployment Commanded DTC B0053 Deployment Commanded with Loop Malfunctions Present DTC B0077, B0078, B0079, B0080, B0081, or B0082 Left Front/Driver Side Impact Sensor (SIS) Circuit DTC B0100, B0101, or B0102 Electronic Front End Sensor 1 Circuit DTC B0184 or B0189 Solar Load Sensor Circuit DTC B0490 Passenger Temperature Control Cooler/Warmer Switch Circuit Range DTC B1000 ECU Malfunction DTC B1001 Option Configuration Error DTC B1004 Keep Alive Memory (KAM) DTC B1007 EEPROM Write Error DTC B1009 EEPROM Checksum Error DTC B1010 Calibration ROM Checksum Error DTC B1259 Antenna Ground Circuit DTC B1327 Device Power Circuit Low DTC B1336 Device Power 3 Circuit Range/Performance DTC B1390 Device Voltage Reference Input CKT Malf DTC B1420 Device Voltage DTC B1422 Device Power Moding Malfunction DTC B1513 Charging System Volts Low DTC B1514 Charging System Volts High DTC B1562, B1567, B1572, or B1577 Mirror Switch Circuit DTC B1582, B1583, B1592, B1593, B1612, B1613, B1622, or B1623 Mirror Position Sensor Circuit DTC B1658 EPROM Read Write Error DTC B1735, B1740, B1745, B1750, B1755, B1760, B1815, B1820, B1830, B1835, B1840, B1845, B1940, or B1945 Power Seat Switch Circuit DTC B1780 Theft Lock Enabled DTC B1825, B1850, B1860, B2355, B2365, or B2375 Power Seat Position Sensor Circuit DTC B1826, B1851, B1861, B2356, B2366, or B2376 Power Seat Sensor Circuit Range Performance DTC B2455 Cellular Phone Microphone Circuit DTC B2470 Cellular Phone Antenna Circuit DTC B2476 Cellular Phone Select Service Switch Malfunction DTC B2482 Cellular Phone Select Service Switch Range/Performance DTC B2483 or B2484 Global Positioning System (GPS) Antenna Circuit DTC B2556 Interior Lamp Rheostat Circuit Range DTC B2627 Pass Compartment Dimming #2 Circuit Low DTC B2628 Pass Compartment Dimming #2 Circuit High DTC B2641 Delayed Exterior Lighting Ctrl CKT Range DTC B2642 Delayed Exterior Lighting Ctrl CKT Low DTC B2643 Delayed Exterior Lighting Ctrl CKT High DTC B2646 Ambient Light Sensor Circuit Range DTC B2647 Ambient Light Sensor Circuit Low DTC B2648 Ambient Light Sensor Circuit High DTC B2757, B2762, B2767, or B2772 Memory Switch Circuit DTC B2805 Steering Whl Controls HVAC Sw CKT Malf DTC B2810 Steering Whl Ctrl Entertainment CKT Malf DTC B2823-B3574 Driver Information Center (DIC) Switch Circuit DTC B2960 Invalid Coded Key Present DTC B3031 Key Decoder Device in Assem Learn Mode DTC B3055 Key Not Present DTC B3109 Keyless Entry Transmitter Low Battery DTC B3142, B3147, B3152, or B3157 Door Lock Switch Circuit DTC B3172, B3177, B3182, B3187, B3192, B3197, B3282, B3287, or B3292 Window Switch Circuit DTC B3377, B3382, B3387, B3392, B3397, B3452, B3457, B3462, B3467, B3472, B3477, B3482, B3517, or B3522 Master Window Switch Circuit DTC B3527 Window Lockout Switch Circuit Low DTC C0625 Level Control Suspension Sensor Malfunction DTC C0628 Level Control Position Sensor Circuit High DTC C0660 Level Control Exhaust Valve Circuit Malfunction DTC C0663 Level Control Exhaust Valve Circuit High DTC C1211 ABS Indicator Lamp Circuit Malfunction DTC C1214 System Relay Contact or Coil Circuit Open DTC C1217 Pump Motor Shorted to Ground DTC C1218 Pump Motor Circuit Shorted to Voltage or Motor Ground Open DTC C1221-C1235 Wheel Speed Sensor Circuit DTC C1236 Low System Supply Voltage DTC C1237 High System Supply Voltage DTC C1238 Brake Thermal Model Exceeded DTC C1242 or C1243 Pump Motor Circuit DTC C1245 Low Tire Pressure Detected DTC C1248 EBCM Turned the Red Brake Warning Indicator On DTC C1254 Abnormal Shutdown Detected DTC C1255 or C1256 ECU Malfunction DTC C1261-C1274 EBCM Internal Solenoid Circuit DTC C1276, P1644, or P1689 Delivered Torque Circuit DTC C1277 or P1571 Powertrain Indicated Traction Control Malfunction DTC C1278 TCS Temporarily Inhibited By PCM DTC C1281, C1283, or C1286 VSES Sensors Uncorrected DTC C1282 Yaw Rate Sensor Bias Circuit Malfunction DTC C1284 or C1285 Lateral Accelerometer Circuit DTC C1287 or C1288 Steering Position Sensor Circuit DTC C1291 or C1293 Brake Switch Circuit DTC C1294 Brake Lamp Switch Circuit Always Active DTC C1295 Brake Lamp Switch Circuit Open DTC P0030 HO2S Heater Control Circuit Sensor 1 DTC P0036 HO2S Heater Control Circuit Sensor 2 DTC P0101 Mass Air Flow (MAF) Sensor Performance DTC P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency DTC P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage DTC P0116 Engine Coolant Temperature (ECT) Sensor Performance DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage DTC P0121 Throttle Position (TP) Sensor Performance DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature DTC P0130 HO2S Circuit Closed Loop (CL) Performance Sensor 1 DTC P0131 HO2S Circuit Low Voltage Sensor 1 DTC P0132 HO2S Circuit High Voltage Sensor 1 DTC P0133 HO2S Slow Response Sensor 1 DTC P0134 HO2S Circuit Insufficient Activity Sensor 1 DTC P0135 HO2S Heater Performance Sensor 1 DTC P0136 HO2S Sensor Circuit Sensor 2 DTC P0137 HO2S Circuit Low Voltage Sensor 2 DTC P0138 HO2S Circuit High Voltage Sensor 2 DTC P0140 HO2S Circuit Insufficient Activity Sensor 2 DTC P0141 HO2S Heater Performance Sensor 2 DTC P0171 Fuel Trim System Lean DTC P0172 Fuel Trim System Rich DTC P0201-P0206 Injector Control Circuit DTC P0218 Transmission Fluid Overtemperature DTC P0230 Fuel Pump Relay Control Circuit DTC P0300 Engine Misfire Detected DTC P0315 Crankshaft Position System Variation Not Learned DTC P0325 Knock Sensor (KS) Circuit DTC P0327 or P0332 Knock Sensor Circuit DTC P0336 Crankshaft Position (CKP) Sensor Circuit DTC P0341 Camshaft Position (CMP) Sensor Performance DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient DTC P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage DTC P0420 Catalyst System Low Efficiency DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected DTC P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit DTC P0446 Evaporative Emission (EVAP) Vent System Performance DTC P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage DTC P0455 Evaporative Emission System Leak Detected DTC P0462 Fuel Level Sensor Circuit Low Voltage DTC P0463 Fuel Level Sensor Circuit High Voltage DTC P0480 or P0481 Cooling Fan Relay Control Circuit DTC P0496 Evaporative Emission System High Purge Flow DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input DTC P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent DTC P0506 Idle Speed Low DTC P0507 Idle Speed High DTC P0522 Engine Oil Pressure (EOP) Sensor Circuit Low Voltage DTC P0523 Engine Oil Pressure (EOP) Sensor Circuit High Voltage DTC P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit DTC P0560 System Voltage DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, P1683, or P2610 ECU Malfunction DTC P0620 Generator Performance DTC P0641 Sensor Reference Voltage "A" Circuit/Open DTC P0645 A/C Clutch Relay Control Circuit DTC P0650 Malfunction Indicator Lamp (MIL) Control Circuit DTC P0651 Sensor Reference Voltage "B" Circuit/Open DTC P0711 TFT Sensor Circuit Range/Performance DTC P0712 Transmission Fluid Temperature (TFT) Sensor Circuit Low Input DTC P0713 Transmission Fluid Temperature (TFT) Sensor Circuit High Input DTC P0716 Input Speed Sensor Circuit Intermittent DTC P0717 Input Speed Sensor Circuit Low Input DTC P0719 Brake Switch Circuit Low Input DTC P0724 Brake Switch Circuit High Input DTC P0730 Incorrect Gear Ratio DTC P0741 TCC System Stuck Off DTC P0742 TCC System Stuck On DTC P0748 Pressure Control Solenoid Circuit Electrical DTC P0751 1-2 Shift Solenoid Valve Performance DTC P0752 1-2 Shift Solenoid (SS) Valve Performance - No Second Or Third Gear DTC P0753 1-2 Shift Solenoid Circuit Electrical DTC P0756 2-3 Shift Solenoid Valve Performance DTC P0757 2-3 Shift Solenoid (SS) Valve Performance - No Third Or Fourth Gear DTC P0758 2-3 Shift Solenoid Circuit Electrical DTC P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage DTC P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage DTC P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage DTC P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage DTC P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage DTC P1121 Throttle Position (TP) Sensor Circuit Intermittent High Voltage DTC P1122 Throttle Position (TP) Sensor Circuit Intermittent Low Voltage DTC P1133 HO2S Insufficient Switching Sensor 1 DTC P1134 HO2S Transition Time Ratio Sensor 1 DTC P1351 Ignition Coil Control Circuit High Voltage DTC P1352 Ignition Bypass Circuit High Voltage DTC P1361 Ignition Control (IC) Circuit Low Voltage DTC P1362 Ignition Bypass Circuit Low Voltage DTC P1374 Crankshaft Position (CKP) High to Low Resolution Frequency Correlation DTC P1380 Misfire Detected - Rough Road Data Not Available DTC P1381 Misfire Detected - No Communication with Brake Control Module DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance DTC P1536 Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled DTC P1540 Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled DTC P1554 Cruise Control Feedback Circuit DTC P1575 Extended Travel Brake Switch Circuit DTC P1585 Cruise Control Inhibit Output Circuit DTC P1626 Theft Deterrent Fuel Enable Signal Lost DTC P1630 Theft Deterrent Learn Mode Active DTC P1631 Theft Deterrent Start Enable Signal Not Correct DTC P1640 Control Module Output A Circuit DTC P1650 Control Module Output B Circuit DTC P1660 Control Module Output C Circuit DTC P1670 Control Module Output D Circuit DTC P1811 Maximum Adapt and Long Shift DTC P1814 Torque Converter Overstressed DTC P1819 Internal Mode Switch-No Start/Wrong Range DTC P1820 Internal Mode Switch Circuit A Low DTC P1822 Internal Mode Switch Circuit B High DTC P1823 Internal Mode Switch Circuit P Low DTC P1825 Internal Mode Switch - Invalid Range DTC P1826 Internal Mode Switch C Circuit High Voltage DTC P1860 TCC PWM Solenoid Circuit Electrical DTC P1887 TCC Release Switch Circuit DTC U1000 and U1255 Class 2 Communication Malfunction DTC U1001-U1254 Lost Communications With XXX DTC U1161-U1163 or U1170 Lost Communications With XXX Door Module DTC U1300, U1301, or U1305 Class 2 Data Link Low or High DTC U1500 Inter-device Dedicated Bus 1 --------------------------------------------------------------------------------
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
