| Latest | 0 Rplys |
10-02-2010, 05:03 AM | #1 | |
1986 camry ngine just stopped
1986 camry with 216k was running fine then just quit ,the engine turns over but won't start.
10-02-2010, 02:30 PM | #2 | |
Re: 1986 camry ngine just stopped
start by checking for spark & fuel.a shot of carb cleaner in carb will give
you an idea if its a fuel problem
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
10-02-2010, 05:07 PM | #3 | |
AF -Advisor
First check to see if the timing belt is still intact. Remove the distributor cap and have someone turn the key to the start positon while you observe the rotor. If the rotors spins when the engine rotates, the timing belt is OK. If it does not spin, the timing belt is broken. If the timing belt is still intact, I would then check for fuel and spark as inafogg suggested.
Mike |
10-03-2010, 12:42 PM | #4 | |
AF -Advisor
Checking the ignition rotor is a sure fire way to determine if a timing belt is broken but a quicker way to at least get a wag on if it's broken or not is to just listen to the engine rotate as you crank it.
When the belt is broken the valve train won't move leaving most if not all of the valves open. With the valves open zero compression is produced. Since there's no compression pressure created the engine has no force to overcome as it spins when you crank it. Your engine will spin much faster than usual. Listen for that "high speed spin".
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
10-05-2010, 09:53 AM | #5 | |
The RustBuster
Check the ignition coil, especially if it is the original part. Pretty common to go out.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
