11-07-2004, 01:37 PM | #1 | |
No Low Beams!
I have a 1993 Suzuki Sidekick that only the high beams work. Its a Canadian model that has the Daytime Running Lights (DRL) which are not working either. I took an educated guess that the Combination switch was bad and replaced it with no luck. Any help or advice will be greatly apreciated.
11-16-2004, 06:35 PM | #2 | |
Update--I have managed to find the DRL relay/module that is now the suspected culprit. Now the mystery deepens. The connector that plugs into the DRL relay has one burnt pin. Almost looks like it caught on fire. Not sure if the relay is bad or what. I'll update when I know more.
11-16-2004, 06:46 PM | #3 | ||
Re: No Low Beams!
11-17-2004, 02:16 PM | #4 | |
I thought of that too. I bought 1 new bulb and ONLY the high beams worked on the new bulb so I kind of decided it wasnt the bulbs. I also eyeballed to other bulb and it appeared ok.
11-22-2004, 04:30 PM | #5 | |
Re: No Low Beams!
Just an update. Turns out to have only been a loose connection.
