| Latest | 0 Rplys |
08-17-2012, 09:14 PM | #46 | |
Re: A new noise coming from engine compartment
What?? You're back to the synchronizer!! .... that was the first suggenstion you got ... back on page one!!
(Just kidding ya... mysteries abound in problem solving!) If you can remove the sensor and get a few drops of oil down in that thing, ... it will really change how it works .... if its the problem to start with. |
The Following User Says Thank You to 12Ounce For This Useful Post: |
olopezm (08-22-2012)
08-17-2012, 09:42 PM | #47 | |
Yeah I know man! I'm sorry. I was so narrow minded about the noise being a valvetrain/drivebelt problem that I almost completely ruled out everything else. Besides, I used to know the synchro would make more like a squealing noise; at least those were the stories I've seen posted in the forum, never a tapping/ticking like noise.
Was until I read that the synchro is directly connected to the oil pump shaft; at first I couldn't understand tempfixit's idea until now! I don't know what could cause it to tap but might definitely try putting some oil in it. So, do you think a bad synchro could be causing the symptoms I wrote in my previous post?. I still have too much to learn about this engine, the memories from us rebuilding it are way too blurry to take into account LOL. I appreciate all of your comments 12Ounce and everyone else; I'd be having a hard time without this forum and you guys. Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
08-18-2012, 01:04 AM | #48 | |
I wouldn't think so, when I had the wobbling I noticed no vertical movement indicative of spring failure, just the pulley shaking with its shaft moving back and forth horizontally. Also when I took the old tensioner out I released the spring and examined the tensioner, it appeared do be under full tension. The pulley however, was obviously shot. It would spin freely like a bike wheel when normally there should be some measure of resistance from bearing lubricant. No resistance = no lubricant = no good
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
The Following User Says Thank You to Windstartled For This Useful Post: |
08-18-2012, 11:33 AM | #49 | |
I'm just jerking you around ... noises/leaks/vibrations/electric-problems can be so difficult to find and fix. I'm sure the recycle yards are full of vehicles that had easy-to-fix issues .... that no one could find. We've all been there.
I personally would now guess the problem is not the scychronizer ... but who knows? It would certainly be good maintenance to drop some oil into it. |
08-18-2012, 11:51 PM | #50 | |
Hi Oscar. Bad synchro doesn't make this sound. It actually makes a high pitched squeaky metallic noise, similar one as worn drum brakes shoes noise when you hit the brakes or same as bad quality hamster wheel. So it's not that.
For me it sound like a worn timing chain like other suggest cause it's the caracteristic of a steady rattling noise of a bad timing chain. But it could also be a noisy valve lifter or valve. In these cases I suggest you to switch back to 15W40. It's, normally, not the recommanded oil grade for this engine, EXCEPT when you have a sticky valve lifter, valve or worn timing chain it can cure the noise. But I suggest you before to have it inspected in a garage with a sthetoscope to better diagnose the problem. A broken timing chain will make destroy the engine. Heavier oil will not prevent the chain to fail, but it'll make it last longer. If it's the lifter, you don't have to replace them, just switch your oil grade. Unless if the heavier oil doesn't fix the noise issue. I think it's more the chain because I don't ear tapping, only rattling. The same noise could be caused by the water pump, but if it was the case it'll not be affected by the temp and it'll be a coincidance if it appears after you switch oil grade. And when you remove the belt and but it back, I still ear the noise even if sound is lower in intensity. So if it's the same noise when you remove belt and put it back, it eliminate the water pump completely. I also noticed that even when you rev up, the noise is still there. Maybe you don't ear it because the engine noise cover the sound, but it still there. How much mileage do you have on your engine? In my Taurus with 3.0L OHV engine, I had have replaced the timing chain at 92,000 miles cause it was a little bit loose, even it didn't make any noise and running fine.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar. Last edited by serge_saati; 08-19-2012 at 10:20 PM. |
The Following User Says Thank You to serge_saati For This Useful Post: |
08-19-2012, 07:25 PM | #51 | |||||||||
Just to clarify, are you talking about the rattling noise in the third video? I have tried to pinpoint that one since 2010 with no success. That noise happens only at warm idle from time to time, specially when there is electrical load on the engine (electric fans, windows reaching the end of their race, etc.) . I have an old thread about it HERE . Quote:
Could this have contributed to worn lifters and evolved into the current problem? Quote:
Listening to valve lifters would require me to put the stethoscope ON the valve covers right? Reaching the rear cover will be a challenge... Is there any "hot spot" I should give a try? Quote:
*************** Thank you very much to everyone for your comments. Oscar.
08-19-2012, 08:52 PM | #52 | ||||
This guy in this video has replaced his alternator and the noise has decreased a lot in intensity. Cause he may have another noise.... So remove belt again and record the noise again w/o belt so we can compare. Turn off engine and play with alternator, P/S pumps and all other pulleys. Quote:
The 3 "column" in the valve cover and timing chain cover. Quote:
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar. |
08-19-2012, 09:38 PM | #53 | ||||
Thanks again serge_saati,
What I meant to ask in my previous post is if the rattling noise in that (third) video is the one you think could be a bad timing chain. Or, were you talking about noise in my first two videos only? Quote:
I'll listen with the stethoscope tomorrow and will make another video with the belt removed. Oscar.
08-19-2012, 09:55 PM | #54 | ||
I suggest you to listen to timing chain cover while the serpentine belt is removed, cause you've more space and you'll more focus on its noise. Which model of Fram filter do you consider crappy? Is it the Fram Extra Guard oil filter? http://mx.fram.com/enmx/products/oil...ard_oil_filter What do you think about the Fram Xtended Guard filter?
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar. Last edited by serge_saati; 08-19-2012 at 10:44 PM. |
08-20-2012, 06:33 PM | #55 |
08-20-2012, 07:18 PM | #56 | |
There may have been a systemic problem with Ford tensioners a decade ago. When I go to the salvage yard one out of two vehicles there have their drive belt removed (people collect them for spares I guess) and I noticed that on Windstars, Taurus, Lincoln and some other Fords the tensioner pulley is often loose meaning the bearings are shot. This is much less common on other makes. Also when I hear bearing noises when stopped at a traffic light it often comes from a Ford
08-20-2012, 07:42 PM | #57 | ||
I've never used the xtended guard; over here the only available models are extra and tough guard and most of them have caused loud lifter noise ticking during cold starts on my vehicles. I've used other brands like Delco and Gonher (mexican brand), which caused no noise on startup. I can also say that googling "orange can of death" has revealed lots of problems around the world; different car forums have the same impression about it. I kept using fram because autozone is close to my house and they are cheap but now that I get discount prices at the dealer, I can get motorcraft filters for only $3.60, they will stay in the past. I obviously cannot condemn all of their filters since I haven't tried them all but by experience and general consensus I can say fram stands for low quality. *************** Back to the topic. I listened with the stethoscope while the engine was cold: Timing chain cover: I tried at different spots and I could only listen to what I would consider as a normal chain noise, was like someone dragging a chain around on the floor or manually opening one of those big warehouse doors; I hope you get the idea. Never heard any slapping. Valve covers: While trying different spots, I could notice some of them seemed a bit louder than the rest, I could refer to it like a slight diesel engine sound but nothing excessive and of course, only noticeable with the stethoscope. In any case I couldn't hear any tapping, rattling, slapping, etc. Alternator made no unusual noises and steering pump, the same. While probing on the water pump I could only hear water flowing. Drove it for a few minutes to warm the engine and be able to hear the noise. When I got home I could tell the noise definitely comes from the drive belt area and listening with the stethoscope reveals what seems to be a metallic clicking noise. Seems to be coming from somewhere in the middle of the block (at the height of the idler pulley) and I can still hear it through the oil filter. Removed the serpentine belt, took me only a few seconds, and tried again; noise wasn't there anymore. I've uploaded 3 new videos: Cold engine startup Warm engine with belt installed Warm engine without belt installed Thanks in advance, Oscar
08-20-2012, 07:47 PM | #58 | ||
I like to play the "guess the noise game" every time I'm on the street and have nothing to do. Belt noises around here seem to come more often from Nissan Platina's (mexican version of the Renault Clio Symbol) and most of the times from Dodges.
08-20-2012, 11:37 PM | #59 | ||
So it's really in the engine. I still think it could be the timing chain or the lifters. But I think it's more likely the timing chain. Read this for additional infos on the timing chain noise diagnosis: http://www.ehow.com/how_7648418_diag...in-noises.html A loose chain can cause metallic noise and can cause the lifter and rocker arms to make additional noise too because of the instant acceleration and deceleration of moving parts when you rev up or release gas when it's slack. I suggest you to have someone else or many other people to ear the chain noise with the stethoscope to tell if it's the noise is normal or not as a second opinion.
08-21-2012, 12:59 PM | #60 | |
I removed and inspected my chain around 216k miles... it showed no wear, so it was re-installed and now is at 341k miles. I expect it to go to 500k miles. Mobil1. If I ever replace the chain, the wheels will also be replaced. For some engines... the chains, wheels, take-ups, guides, etc ... are all available as a single kit.
If your chain is the noise maker, it could just be the take-up/tensioner device. They are sometimes defective and fail. I'm not sure, don't remember about the one in the 3.8, if this tensioner has a hydraulic component or not ... it may just be a spring. If it does have a hydraulic component, that might answer why it is sensitive to oil-weight and temperature. ?? |
