06-30-2019, 11:35 AM | #1 | |
Intermittent starting
My brother has a 1974 Nova 406, turbo 350 transmission. He's been having issues when trying to start the engine, it just clicks like the solenoid is kicking in but the starter won't spin. After a couple of clicks it starts up. He has changed the starter 3 times, all new finally went to the small mini starter, no luck. Changed the ignition switch and it worked good for a couple of days then back to the clicking issue. He has also has a new battery, changed the ends. Cleaned and moved the ground wire from the block to the alternator bracket like stock.
Anyone have any suggestions? |
06-30-2019, 02:11 PM | #2 | |
A990 racer
Re: Intermittent starting
When this occurs you need to check for 12v on the solenoid pink wire from the ign switch when cranking. Post back results, also see if the headliites dim when this happens
07-01-2019, 08:17 AM | #3 | |
Headlights only dim a little bit when clicking ,
Only 7.81 to the starter small post. 12.45 volts to big post |
07-01-2019, 12:37 PM | #4 | |
Ok so today we changed the battery and both battery cables and issue if we jump across the solenoid it works
This car has the seatbelt override still hooked up is there something with this that can cause this ? |
07-01-2019, 07:16 PM | #5 | |
'74 - '75 was a ponts or HEI transition time. Just wondering if yours is points and has a firewall resistor that maybe an issue??
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
07-01-2019, 07:19 PM | #6 | |
it's a HEI unit.
I think we might have a ground issue. We're going to check that next. |
08-10-2019, 01:45 AM | #7 | ||
This could be a problem with the contacts in the ignition switch, or the contacts in the neutral safety switch. It could be a problem with connections anywhere in the power supply to the ignition switch, or from ign. switch to "S" terminal. It could also be a heavily-corroded wire. Lots of folks use the existing, semi-rotted harness to trigger a relay (Ford-style solenoid, or Bosch-style small relay) that supplies full power to the "S" terminal. I've done it myself. For the record, 12.45 volts to the large post on the starter is nothing to write home about. You should have 12.6--12.7 volts. Most likely, the battery is under-charged. Charge battery and re-test.
. . For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China. |
