| Latest | 0 Rplys |
09-06-2013, 03:28 PM | #1 | |
327 runs hot
I have a 59 chev belair with a 69 327 in it it has been running fine until this year.
after changing the waterpump it now runs hot(exact same pump as the old one). It increases temp with increased rpm until gauge goes right over to hot. I have changed the rad cap,the thermostat(twice), the heat sending unit, flushed the system ,the rad is only 3 years old. I'm at a loss any ideas |
09-06-2013, 11:22 PM | #2 | |
Nothing scares me anymore
Re: 327 runs hot
This system is pretty basic, so here's some uh... basic ideas.
I would suggest burping the air from the intake manifold. You should have some kind of fitting into the water passages on the intake that you can unscrew, then add coolant until it comes out the hole. Drilling a 1/8 inch or smaller hole in the thermostat will do the same thing. If that has no effect, look at the basics. Is the thermostat installed backwards? Is the waterpump correct? I seem to recall some pumps are reverse -direction, used for serpentine -belt systems. |
09-07-2013, 06:35 PM | #3 | |
Re: 327 runs hot
So, this all happened after a water pump change? If so, I would think you should look there. To me it just sounds like you're not getting a good flow out of the replacement pump and maybe look for a better pump.
57 Chevy 210 65 Olds 442 Convertible (Another one sold) 75 GMC Vandura 3/4 Ton 1999 K2500 Old Body Style Suburban (Gone but not forgotten) 05 Dodge Ram 3500/5.9 Cummins 2012 Toyota FJ Cruiser |
