| Latest | 0 Rplys |
02-18-2014, 12:18 PM | #1 | |
99 crown Vic cranks no start
100,000 miles new fuel pump three months ago all filters changed, new spark plugs and coils. Parked car for the evening next morning would crank no start. It would start when the fuel pump primed, now the fuel pump does not prime, I get no check engine light in the on position and no check engine light when car is cranking. Any help would be appreciated, thanks Paul
02-18-2014, 02:31 PM | #2 | |
Re: 99 crown Vic cranks no start
Do you mean it used to prime before your parked it for the evening? Or now? If you have no fuel pressure now then you can check to see if the fuel pump is getting power by disconnecting the harness and checking for 12.5 volts between the fuel pump power circuit and the ground circuit. Make sure you have a fully charged battery and check in the first 5 seconds after turning the key on.
