03-05-2013, 11:28 AM | #1 | |
water pump
how long should it take to replace a water pump on a 2000 pontiac grand am 4 cylinder
03-05-2013, 12:19 PM | #2 | |
Re: water pump
if it's a quad 4, perhaps the rest of your life.
it's driven by the timing chain, those quad fours are a pain. alldata book time is 6.3 hours. |
03-05-2013, 12:38 PM | #3 | |
Re: water pump
Agree with the above statement. It's a pretty in depth process with special tools required to hold the cam gears in the correct position. If you are going to attempt it I suggest buying and manual and following every step.
The Following User Says Thank You to gmtech1 For This Useful Post: |
barrykeitt (03-05-2013)
03-05-2013, 08:00 PM | #4 | |
Re: water pump
Obviously, you had sticker shock on the price of the job....
This is like a 700-1000 dollar job.....just for water pump, not including additional parts..... When doing the job, belt has to be inspected/replaced..... Now would be the time for a coolant flush.......also replace the thermostat..... The exhaust manifold has to be removed......the timing cover has to be removed......chain, cam sprockets, crank sprocket, guides, and tensioner/shoe all have to be inspected/replaced...... After the pump is replaced, the timing chain is installed and the engine has to be timed, or you end up with bent valves or a poor idle.....then everything is put back together, and coolant added and burped.....this is a quite involved job..... By contrast, if you had a 3.1 or 3.4, the water pump job would be around $200, because it an easy job, less than an hour..... |
03-18-2013, 01:03 PM | #5 | |
out saving the world
Re: water pump
this is a PITA procedure ! I'd agree with picking up a service manual.
This is one i have not wrote up completely for the Tips & Maintenance section. The 2.4L is a lot different than the newer 2.2L, both not much fun. But after you've changed them out 200-300 times, it gets a lil quicker than 6 hrs.
1999 Grand Am SS 3.4 OHV |
