How-To's and Walk-Through's Here's where we show you how it's done! |
11-05-2004, 12:15 AM | #1 | |
Please Help Me!!
can someone please tell me how to stop my car from the RPM'S racing between 1,000 & 3,000 it like goes down to 1 and races back to 3 and goes back and forth the whole time out of gear it's a 5 spd 2.2 stock motor with turn down cold air intake please reply and tell me how to stop it from doing that cause it is a pain and it's burning all my gas.
11-08-2004, 05:58 PM | #2 | |
Re: Please Help Me!!
Does this happen when you are in nuetral or when your in stopped in first. That use to happen to me with my 91 accord. I had to get my engine flushed out also my transmission flluid. (At least this is what I was told I had to do.) But it seemed to have fixed the problem. It happened to me when I was in nuetral
11-12-2004, 07:41 PM | #3 | |
may be a timing problem, i dont see why the fluids would cause it to do that. your best bet would be to take it to a mechanic and see what they have to say. one of my neighbors has the same problem with his lude and i havent had a chance to speak with him about that because of a language barrier
11-13-2004, 09:24 AM | #4 | |
i think it's your idle control valve ( a little thing behind your intake manifold w/ 1 wire and 2 coolant tubes running out, about $70 from dealer). same idle problem happened to mine, changed out the icv and problem solved.
11-13-2004, 09:32 PM | #5 | |
It is either your IACV or your coolant could be low. Check the coolant level first and if it is full then it is most likely the IACV (intake air control valve).
