| Latest | 0 Rplys |
05-27-2005, 08:13 AM | #1 | |
Rear End Clunking Noise
Apparently, this isn't a serious problem because it has occurred ever since I bought my '99 Yukon 4WD in 2000 with 33,000 miles. It now has 120,000 miles. Sometimes, when I stop, then start out like at a stoplight, I hear a single clunk in the rear end, like something sticks, then releases when I start rolling. It doesn't always do it, but it occurs fairly frequently. Is it the rear differential sticking, or brakes not releasing, or something different? I've had all the transverse gear and other oils and lubes changed, but it didn't affect the clunk sound.
I mentioned it to the dealer service writer once, and he said that these vehicles do that. Thanks, |
05-28-2005, 12:03 PM | #2 | |
Bob; I know this is gonna sound crazy, but check your motor and trans mounts. I had the same problem with my 89 full size blazer.........Good Luck .........Mike
Leave that alone!!!! it'll grow on its own |
05-29-2005, 09:27 PM | #3 | |
Re: Rear End Clunking Noise
Bob
It is your suspension that is mounted to your axle housing. No big deal mine does the same thing. Drives me up a wall. the torque on the axle when you take off makes it twist. It is called loading and unloading |
05-30-2005, 09:54 PM | #4 | |
It could also be u-joints, transmission, t-case, and many other things.
You can't really narrow it down any more without more information. And cbconstruction, there should not be any noise coming from your spring perches. Yes the axle will rotate a little (actually called "axle-wrap") and slightly "twist" the leaves, but it should not make any noise....since the are mounted VERY solid'ly to the axle housing |
06-02-2005, 09:12 AM | #5 | ||
06-06-2005, 08:05 AM | #6 | |
I had the exact same problem on my 2001 Yukon XL (my threads were posted about 1 year ago here). Took it in and the rear housing had a few loose gears and other things in it. At a red light, when I accelerated, I would sometimes hear a "clunk" and sometimes (most times) I would hear a "whirl;, whirl, whirl" that got faster as I went faster.
06-07-2005, 08:22 AM | #7 | ||
Re: Re: Rear End Clunking Noise
