| Latest | 0 Rplys |
#61 | |
Re: A new noise coming from engine compartment
In the video without belt on I noticed at about 30 seconds a pulley is turning (not the harmonic balancer) by the oil filter., could it be the culpirt?
The Following User Says Thank You to tempfixit For This Useful Post: |
olopezm (08-22-2012)
#62 | |||
An it's the crankshaft pulley. The harmonic balancer (vibration damper) is located behind it. Quote:
Yes there's an hydraulic tensioner for the timing chain of the 3.8L. In bottom of the picture. ![]()
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar. ![]() |
The Following User Says Thank You to serge_saati For This Useful Post: |
#63 | |
After watching video again you are correct it is the cranshaft pulley, I thought it was still the idler pulley still turning somehow. My mistake.
#64 | |
12Ounce, does the Mobil1 oil is the best? I thought it was Castrol Edge with "Titanium" fluid technology - synthetic. Do you use Mobil1 oil filter too?
Do you really plan to make your Windstar reach 500K miles? How many times did you replace/rebuilt your transmission up to now?
#65 | |
What is the best oil? What is the one and true religion? I have no idea.
I use Mobil1 after making some "study" years ago, ....but now, years later, its just habit. It seems to work very well for me, I'm amazed at the little metal wear I see on internal parts. And I rely heavily on oil tests done by Blackstone Labs that keep me on course. There may be "better" oils ... but I don't know why I would change at this point. I use the Purolator PL series oil fiter. |
The Following User Says Thank You to 12Ounce For This Useful Post: |
serge_saati (08-22-2012)
#66 | ||||
![]() ![]() Quote:
You'll see, this Windstar overheated twice, the first time was because of a corroded water pump impeller that disintegrated and the second was caused by air in the system. We rebuilt it both times and as I mentioned before I can't remember if we replaced any of the timing components, we might have done it the first time but not the second; at this point I would say we didn't and I'm guessing that's the reason why the chain and/or tensioner are failing. Now I'm convinced that the problem is at the chain and not the lifters; as I said before, the noise is more noticeable at the timing cover rather than the valve covers. Quote:
That must be the reason because the noise seems to be coming from the middle eight of the engine, by the idler pulley's height. I'm pretty sure if I manage to listen at the back tensioner the noise will be more audible there. Guys, from your comments, I say I will have to replace the timing chain and tensioner (from the image, I guess it must come with the guides) AT LEAST. Would that be ok if I can get them by separate, or should I just bite the bullet and get it as an assembly with the sprockets? Replacing the chain itself is a PITA; I would like to know if there's any chance for the sprockets to go bad. If that's the case then I'll surely get the whole thing so I won't have to deal with it again. *********** Since the noise is more noticeable as the engine warms up, it would be "safe" to run the engine a few minutes so I can maneuver the Lincoln out of the garage? My garage is supposed to be for 2 vehicles, but has enough space to actually store 3 vehicles and in order to get it out, I'll need to move the windstar. It shouldn't be more than a few minutes and wouldn't even reach normal temp. What do you guys think? I wonder if anybody has any tips on this task. I understand I'll have to: -Set engine at TDC -Drain the oil and coolant -Remove the tensioner and idler pulleys -Remove the alternator -Set the steering pump aside -Set the A/C compressor aside -Remove the crankshaft pulley and dampener *1.- Will I need to remove the oil filter adapter and pump from the engine? *2.- Will I need to remove engine mount nut in order to raise the engine? *3.- Should the water pump be removed first, or is it possible to remove it while still attached to the timing cover? *4.- I think I must remove the passenger side oil pan bolts. Will that be enough or should I remove the entire oil pan. *5.- Is it necessary to remove the cam synchronizer? *6.- Should I replace the crankshaft seal on the cover or not?. There are no oil leaks ATM. I checked the manual but the procedure stated in it only covers the removal for the 3.0 engine. This thing will remain parked for some time now until I can afford it. Oscar.
1995 Lincoln Town Car 4.6 Signature 1997 Pontiac Grand Prix GT 3.8 2000 Ford Windstar SE 3.8 |
#67 | |
I would be hesitant to take lay out such bucks. Have you ever tested the oil pressure?
Disintegrated water pump impeller, eh. Let me guess: plain, or even worse ... distilled water, used as a coolant ... with no anti-freeze, or anti-rust added. ?? |
#68 | ||
I have no idea about why the impeller disintegrated; when we bought the van it had proper coolant in it, looked a bit diluted though... Oscar.
#69 | |
Oscar have you looked at the engine oil pressure tester at harborfreight.com, I do not know how much shipping would cost but might be worth checking into.
#70 | |
Hi tempfixit, yeah I already took a look at it and I'm interested in the oil pressure gauge and a solar panel to keep batteries charged but I'm just waiting to see if the guy from the store can get the gauge or not, I'll be seen him tomorrow.
I really appreciate your input and will keep you informed if I decide to get anything form that web. Oscar.
#71 | |
In the hydraulic tensioner you have a valve. So it's not operating at full pressure. So even a minor drop in the pressure will not cause the chain to be loose. The other proof, is that when you accelerate I still ear the noie. So I don't think the tensioner is loose because of the lack of pressure. It could be the chain itself.
2003 Chevrolet Impala LS 3.8L OHV 2002 Ford Taurus SE 3.0L OHV (sold) 1998 Ford Windstar LX 3.8L OHV (sold) 2002 Chevrolet Malibu LS 3.1L OHV (sold) 2004 Hyundai Accent GS 1.6L DOHC manual (sold) 1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold) 2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold) A Windstar without having the check engine light is not a real Windstar. ![]() Last edited by serge_saati; 08-22-2012 at 09:59 PM. |
olopezm (08-23-2012)
#72 | |
2000 Dodge Dakota SLT 4x4 5.9L V8 - Brutal 2008 F150 FX4 5.4L V8 - Wintermobile 2000 Windstar SE 3.8L V6 - Beast of burden 1995 BMW 540i 4.0L V8 - Weirdest car ever owned |
The Following User Says Thank You to Windstartled For This Useful Post: |
#73 | |
I have an oil pressure test gauge kit that is all simple mechanical. No electrics or exotics. I use it for tranmission fluid and engine oil pressures. 0 - 300 psi. IIRC. The cost was less than $30 at AutoZone a couple of years ago.
#74 | |||||
******** I couldn't get to see the guy form the store but will try again tomorrow. Had to take my mother to see the doctor and was a little busy today. None of you said anything about my previous question and I'm interested to know what do you think? Quote:
Oscar.
#75 | |||
olopezm (08-24-2012)
