| Latest | 0 Rplys |
10-28-2022, 09:01 PM | #496 | |
Re: Lola T-70 Mk III
The exhaust system and rear tray are installed. The dashboard assembly is installed. Getting closer to begin mounting some of the body panels to the tub…
10-29-2022, 03:14 AM | #497 | |
Again, stunning attention to detail.
10-30-2022, 07:11 PM | #498 | |
Thank you Mp!
Another significant step forward, the last section of the body has had the paint cut and polished. The insides are painted as well. Once that is dry it will get some wax. (It's quite the dust magnet right now.) |
10-31-2022, 01:49 AM | #499 | |
That is an unbelievable shine. I have yet to achieve a similar result. Truly stunning.
11-03-2022, 04:47 PM | #500 | |
Thanks! Just keep practicing.
Several people have pointed out the risks of using the kit supplied air duct hose as it has a propensity for melting plastic over time. While I was already aware of this issue, (the ones in this kit melted some of the parts well before I started building it), and have been lucky in the past, I decided I have too much invested to take that risk even with the precautions taken on this car. I also was not keen on the color of them. So I pulled them off and fabricated new ones from wire and white glue. I wound the wire around the proper sized bolt for the diameter I wanted. After the glue dried I made connectors with shrink tubing. I painted them with orange R/C car (Lexan) paint and gave them a wash of Tamiya Smoke with Flat Base mixed in to it. Plenty of flex to route them where they need to go and a direct retrofit to boot. |
The Following User Says Thank You to Scale-Master For This Useful Post: |
Mpfiend (11-04-2022)
11-04-2022, 02:06 AM | #501 | |
That is a great tip!
Do you just flow the white glue into the gaps on the wound wire? Regards, Keith |
11-04-2022, 06:42 AM | #502 | |
great details !!!
Micha |
11-05-2022, 04:11 AM | #504 |
11-13-2022, 11:06 AM | #505 | |
The rear spoiler is done. Brass, clear styrene and aluminum. Some of the bolts will anchor it to the body.
11-26-2022, 02:00 PM | #506 | |
The radiator is installed and the cooling system has been plumbed. I'll install the stone guard and petcock later due to them being somewhat fragile.
11-27-2022, 01:03 PM | #507 | |
The shifter linkage was the next "little" project to make and install. I was a little surprised the kit did not have the exterior part of the linkage. Turns out it's quite a tight fit, maybe that’s why it was not included. The extra parts I added and the correctly scaled engine did not help.
I'm still relying on the magnets to hold the body section to the tub, but since I've run the shifter linkage all the way from the shifter to the transmission I'm pretty committed at this stage. I also connected the electrical items that were built onto the rear bulkhead to the receptacles on the tub and the fuel lines. The transmission cooler has been installed and plumbed. If it was a real car, it could be test fired now. |
mrgixxer (11-27-2022)
11-27-2022, 01:51 PM | #508 | |
I ran out of superlatives a long time ago. Now I’m just wiping drool off my key board and wondering how in the hell you’ve pulled off a build this impressive. Can’t wait to see more progress!!
11-28-2022, 06:20 AM | #509 | |
I am constantly stunned by the level of detail - not only how much, but how accurate. There is hardly a part that doesn't look authentic.
11-29-2022, 03:39 PM | #510 | |
Thank You!
While not a big visual thing, the cockpit section of the body has finally been permanently mated to the tub. Now I get to build the rest of the interior into the car. Nowhere near the ship in a bottle game; but the limited access proving to be the challenge had I expected in a couple of areas despite my optimistic planning. The seats are installed hopefully for the final time. The steering wheel can be popped to install the harnesses. |
