Go Back   Automotive Forums .com Car Chat > GMC > Jimmy
Old 06-28-2006, 09:46 AM   #31
jdmccright
The RustBuster
jdmccright's Avatar
Re: 95 Jimmy 4.3 Vortec starting problems - weird
This is getting confusing dealing with two different truck setups *sigh*. The '93 using a TBI injection system and the '95 using a CMFI system...you cannot compare the two beyond their basic operation, but they both do utilize some of the same sensors and valves. I will retract the coment about the cold start valve...I was premature in saying there definitely was one on these trucks unless someone else can back me, but I cannot find one on any version of injection system for the Jimmy.
That being said, if the '95 starting issue is resolved then this thread should be closed. If not, then it seems the only things left to check are the injectors, the poppet valves, the spider unit itself, and the fuel pulsator. Something in the system isn't keeping the fuel lines pressurized.
For the '93, I would look at the injectors, regulator, . If you're cranking and you're not smelling ANY gas from the TBI throat, there ain't no gas goin' in...simple as that. A fuel pressure check would help to diagnose which end to look at.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
jdmccright is offline   Reply With Quote
Old 06-28-2006, 12:53 PM   #32
wb8yjf
I can see why this is confusing...mine is a 4.3 CMFI Vortec. Took me awhile to finally get it right.
wb8yjf is offline   Reply With Quote
Old 06-28-2006, 12:54 PM   #33
Megs1082
The 93 is also CMFI injected. 4.3 Vortec - Vin W.
Megs1082 is offline   Reply With Quote
Old 06-28-2006, 01:50 PM   #34
rlith
rlith's Avatar
Send a message via AIM to rlith Send a message via MSN to rlith
Actually it's CPI (Central port injectected) wheras 96+ is CSFI/CMFI (Central sequential fuel injection, or Cental Multiport Fuel Injection if the upgrade has been don)
rlith is offline   Reply With Quote
Old 06-28-2006, 05:20 PM   #35
wb8yjf
Ok. Now I'm really confused. I thought mine was CMFI (1995). I have a central "control" in the intake with a spyder assy. attached to that. I replaced the regulator on the back of the "central" part per info. in the FAQ's. Please tell me exactly what I have! I don't wanna look too stupid....
Thanks!
Jon
Old 06-28-2006, 05:31 PM   #36
rlith
rlith's Avatar
Thanks!
Jon
Yours is CPI (Central port injection). It uses a central spider assembly that batch fires (fires all injectors at once)
96+ CSFI/CMFI is similar in concept but each injector fires individualy based on rotor position (165432)
Old 06-28-2006, 09:04 PM   #37
Megs1082
according to the chilton I do have a 93 CMFI - we just verified tonight, and according to the chilton there is no CPI??????
anyway
I took off the upper manifold, there is fuel sitting in the bottom of the fuel pump regulator side. This could be a problem. I'm not sure what this means...
Here are a few pics. Does anyone have any thoughts?
http://www.geocities.com/jvonengeln/gmc.jpg
http://www.geocities.com/jvonengeln/GMC2.jpg
http://www.geocities.com/jvonengeln/GMC3.jpg
also there is a thread dedicated to my problem, but no one has responded!?!?!?!?!?
http://www.automotiveforums.com/vbul...=575706&page=3
Old 06-28-2006, 09:14 PM   #38
excheezhead
Exclamation Re: 95 Jimmy 4.3 Vortec starting problems - weird
in a previous post on 96-up 4.3L with W code, gm uses 1 term, CSFI. if the customer complains during warrenty about rough idle/hard starting, there is a clean and inspect procedure.
if customer still complaines under warranty, there is a list of conversion parts that will re-fit it to CMFI. as old master and blazee have explained, the conversion does 1 main thing usefull, it eliminates the popet injectors with more reliable and less high maintenance injectors and a new MFI module. i have been trying to see it this bulletin turned into a factory upgrade and what year it started, but i have had no luck so far. i do know that my 2001 still has CSFI, and i plan to do the mod as soon as the outside temp. here in south florida drops, as i have no carport or garage, and i ain't paying 4 hours shop rate to put in 275USD worth of parts. the bulletin is fairly well illistrated and all the needed gm p/n's are there. the only part of the cleaning i cant do is the nitrogen bottle blow down, but if i do the mod, thats not needed. so, if you are medium mechanically inclined and want to eliminate the future hassle of popet injectors misfiring and needing extra maint., i checked gmpartsdirect, and the parts including oring sealer, cleaner and the spider assembly and mod are $275+-USD and shipping. my $o.o2, its worth it to get that off my mind for the next 50,000 mi's.
excheezhead is offline   Reply With Quote
Old 06-28-2006, 09:45 PM   #39
rlith
rlith's Avatar
[quote=Megs1082]according to the chilton I do have a 93 CMFI - we just verified tonight, and according to the chilton there is no CPI??????
anyway
look at the how-to that's posted...
Your pics don't work
Another reason I don't like chilton manuals...
CPI=Central Port Injection...92-95 4.3 motors
CSFI=Central Sequential Fuel Injection 96-2000
CMFI=Central Multiport Fuel Injection-2000-2004 Standard, 96-1999 if you had injection problems (clogged, stuck open) and had the system upgraded. This was actually a recall issue for california I believe.
This is a CPI motor and CPI unit.. See thread here for more pictures...http://www.automotiveforums.com/vbul...ight=regulator
CSFI
CMFI
(Note, the CMFI above is the 8 cylinder version, no diff in the 6 really except less 2 nozzles) CMFI will work in CSFI motors w/ the conversion kit
Old 06-28-2006, 10:31 PM   #40
wb8yjf
OK, according to what I'm hearing and seeing, I have a CPI engine. THANK YOU guys for clearing that up for me! I used that info from the FAQ section to replace my regulator.
This place rocks....
Old 06-29-2006, 06:43 PM   #41
batkoach
yes from your pix this is a CPI unit. if it was starting with a jump but not on its own with a new battery there is a possibility you are drawing to much current and the voltage is dropping down to around 10 to 9 volts during cranking and the computer will not function when voltage drops this low there for no fuel injection however you may still get spark because it starts with the ignition module then switches to bypass for computed timing once the truck starts. check with a vat-40 tester if possible or two meters to check amp draw and how low voltage goes when cranking and if it is dropping to the voltages above ( around 9 to 10 volts0 then your starter is drawing to much current . a normal starter should draw between 125 and 175 amps. if more and volts dropping then this would explain why is starts with a jump as it is getting the additional ampsand voltage from your wifes truck.at this point replace the starter. if this checks ok then the test for the cpi is as follows . check fuel pressure if between 55 to 60 psi with key on engine off this is normal then you will need to do a fuel volume test . most quality gauges have this. there will be a small dia. hose with a valve coming off the gauge. get a 1 QT motor oil bottle with the see through edge and place hose in bottle and disconnect primary connector at ignition coil and have someone crank engine. with a watch time the fuel going into the bottle for 30 seconds . in 30 sec's normal volume should always be 1 pint or 1/2 a qt. if this is what you have replace your CPI . if you have the pressure but insufficent volume then your regulator is working and you will need to replace your fuel filter and if that does not work your fuel pump is done. thanks for listening, john harrier 20 year master machanic in michigan.
batkoach is offline   Reply With Quote
Old 06-29-2006, 07:03 PM   #42
rlith
rlith's Avatar
Well, if you read at the beggining of the thread, he states it fires fine when he sprays starter fluid or gas down the throttlebody, he has a new pump, etc etc. Basically he has lost pressure somewhere. Either in the nut kit or regulator, the issue is not a voltage one, the issue is not getting fuel. The only thing at this point that could combine the two is if the CPI is completely shot or the connector is bad.
Old 06-30-2006, 10:31 AM   #43
wb8yjf
What would be the benefit of converting to a CMFI type system as opposed to the CPI? I know one thing, the spyder assy. on the CPI units look a lot less durable than the CMFI judging from the photos. Can this be done? The $350 or so for that cheap looking spyder for the CPI is mighty pricey...
Just curious.
Thanks!
Jon
Old 06-30-2006, 12:22 PM   #44
rlith
rlith's Avatar
they're both durable...
To upgrade to the CMFI you would need to swap out the following with 96+
Heads
Lower intake
Upper intake
Throttle body
EGR system
Engine Harness
ECM
Various sensors
A few other things
Old 06-30-2006, 02:42 PM   #45
wb8yjf
Well, that settles that. I'm sticking with what I have.
Thanks for the info!
Jon
