| Latest | 0 Rplys |
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
05-31-2007, 06:14 PM | #16 | |
Re: new idea?
what i meant to say was that you can calculate the heat rise, but it will always be higher due to the fact that no compressor is 100% efficient.
it is well known that roots blowers usually operate at around 55% efficiency or so. turbos generally get as high as 85% and can go higher if made right. the more efficient your compressor, the better job it will do at NOT being an enormous hair dryer. basically, i was sitting around one day and had an idea. i asked if anyone liked it and got a resounding NO. nobody explained why, or bothered to go into detail. the answer was NO. even if the idea was dumb, i would still have the sense to try to explain to the person why it wouldnt work and give examples. granted, you guys do have to put up with a lot of idiots asking how to make their civic have 500 hp and such, but still... anyway, to answer beef_bourito, my idea was that you would have this turbine mounted inside a metal intake pipe similar to a typical K&N aftermarket intake. there would be a belt going to a gearbox on the outside of the pipe, which would gear up the turbine to necessary speeds to compress air. the gearbox would have a belt that would be spun by the engine it isnt too developed, but that was my idea. anyway. |
05-31-2007, 06:23 PM | #17 | |
That thing got a Hemi?
Re: new idea?
so basically you want to remove the rough flow path you get with a turbo or blower?
if that's what you mean, it won't make much difference because the intake runners smooth out the flow and remove much of the "turbulence"
Seatbelts Saved My Life |
05-31-2007, 10:10 PM | #18 | ||
Re: new idea?
To further damp out your enthusiasm, read this: http://navier.stanford.edu/bradshaw/.../axialfan.html |
06-01-2007, 02:08 AM | #19 | |
Re: new idea?
Axial fans are also terrible at compressing air.
They work best with large flows and very small pressure increases (i.e. a shower fan). |
09-03-2007, 12:50 AM | #20 | ||
Re: new idea?
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable. |
10-13-2007, 08:38 PM | #21 | |
Re: new idea?
alot goes into the design of a turbo housing. Most of those electric superchargers that push air in are bogus.
