| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
11-10-2006, 01:26 AM | #16 | |
AF -Advisor
Re: Friends Car Vandalized
180* F is considered the minimum by most. This is enough to remove condensation.....slowly
The highest allowed....well, depends on the application. oil/air cooled bikes see 300* F now and then, even higher, for motors that have been played with/are messed up. The biggest issue with the higher oil temps is oil break down. The higher it is, the quicker it breaks down. If you have crappy oil, such temps could cause the oil to break down very rapidly. I don't think most cars run anywhere near that though. Not a common thing people check.
life begins at 10psi of boost Three turbo'd motorcycles and counting. |
11-10-2006, 09:00 AM | #17 | ||
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them. Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood. On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear. |
11-10-2006, 09:42 AM | #18 | ||
AF - Advisor
If it actually happened it sould be reported to the police and insurance company and to his parents. If any damage happened to it it wouldbe covered under comp insurance. And like said the oil sould be changed and and he should have a sample of the oil sent off to be checked.
11-10-2006, 02:28 PM | #19 | |
As mentioned earlier engine flush will break down the oils viscosity - even if the flush evaporates the oil is no longer molecularly sound. The molecular structure and properties of the oil don't return to normal once the flush is evaporated.
...and engine flush has been known to dislodge sludge in the engine...sludge which accumulates in the oil pan and gets sucked up and clogs the oil pump. Who the fu(k cares if daddy finds out? He'll be more pissed if the car throws a rod because there's no oil - especially if he finds out you knew about it. |
11-10-2006, 03:24 PM | #20 | ||
11-10-2006, 05:33 PM | #21 | ||
The ONLY way to change an oils viscosity is to change it's molecular structure - whether by heat or by chemical reaction to engine flush. You can't "dilute" oil with something that doesn't change it molecularly, such as water. Oil and water don't mix and can be seperated easily because the molecular structure of the oil remains intact. |
11-11-2006, 10:33 PM | #22 | ||
Take some heavy weight oil, mix in some lighter weight oil and see what the result is. Noone but you has mentioned water. |
11-11-2006, 11:47 PM | #23 | |
but engine flush is just that... REALLY light weight oil like stuff with a LOT of detergents.
i dont see what the big problem is. people are saying he should have the oil sent to a LAB and be CHECKED??? fine. do it if it makes you feel better, but CHANGE THE FKUCER... and be done with it. thats my opinion. really, why risk engine damage? if a quart of engine flush was poured in, it would do some serious damage if not treated. |
11-13-2006, 05:26 PM | #24 | ||||
Lubricants and solvents are two different things. The point isn't really worth arguing...believe what you will...but I suggest you try your oil experiment for youself. |
11-13-2006, 09:44 PM | #25 | |||||||
also, you can't "break down the oils viscosity" you can break down the oil, you can change its viscosity by dissolving things in it or dissolving it into other things, you can change the viscosity by changing the surroundings (ie temperature, pressure humidity, etc) but you can't break down a property.
11-13-2006, 10:08 PM | #26 | ||
just to clear up a few things. but i think the big consensus it that he should change the oil if he hasn't already because it'll reduce the lubricating abilities of the oil and could ruin the engine.
11-13-2006, 10:23 PM | #27 | ||
When you measure viscosity (by any method, even pouring it) you are seeing the average viscosity. You cannot see the different effects of the small and long chain molecules. Diluting oil adds more small chain molecules and reduces the average viscosity. Comparing engine oils to water, olive oil and vinegar is stretching things a little. Your analogies are lacking, your chemistry is too. |
