Originally Posted by Dr0pZ0n3
other thing you could do if you find out that it's the trans, is a manual swap.
You will need a [clutch, pressure plate, Throw Out Bearing (clutch release bearing], flywheel, pedal set, clutch cable, [shift linkage, shift stabilizer rod], Transmission, and new front mount for the trans.. it's the smallest mount, bolts on right in the front, on the "bellhousing" of the tranny.
P.S. the things in brackets usually come as one piece, or in a kit, and if you know anything about junkyards, you can get most of the stuff pretty cheap.
you'll also wanna go to a parts store and get a hayne's, chilton, or helms manual, as there will be alot of uncovered territory for you. (And make sure you have help, and preferably from someone that knows what they're doing.)
Anyway, the swap is pretty straight forward, if you decide to do it, GL and happy motoring.
