| Latest | 0 Rplys |
04-05-2012, 05:59 PM | #16 | ||
Re: F'in CEL still comes on!
did they check for voltage at the tranny power connector? probably not. also at that connector they can check for ohms , of these 2 solenoids ! there gonna change parts and guess at your expense ! I hope you are not gonna take that . this is an electrical problem not a fluid flow issue. |
04-06-2012, 05:03 AM | #17 | |
I can't understand the problem diagnosing this. The first thing I'd check is the power at the tranny connection like you said, then work either direction from there depending on the results. I know it has to be checked under certain parameters and length of time, but it's just not rocket science. TCC PWM "open" isn't that complicated to me. My wife was an F-15 Avionics test tech in the Air Force, and she's wondering why they can't just follow the circuit and verify each segment. I wonder, too.
2004 Yukon XL Denali Luxo-barge for towing. 6.0L AWD grandpa hauler 2005 Suburban 1500LT/awd/tow/everything else...soccermom cruiser 2008 Nissan Versa HB...wife's skateboard 1997 Jaguar XK8 convertible...best road car ever 1966 Mustang GT convertible...fully restored concourse show car |
04-06-2012, 07:44 AM | #18 | ||
the dealership tech's just do not have the training to do this type of work. my guess is they will tell you the comeplete harness needs replacing . this is because they are incompetent. your wife with the proper wiring diagrams should have a better chance to repair this than the dealership. usn 6yr ETR . |
04-09-2012, 01:01 PM | #19 | |
Here's the latest bad news on this issue: dealer S.M. says the ecu/pcm is bad, and that is causing the cel and code to keep coming back. He says all the circuit and the internal elect. parts are ok.....but the tranny taking longer to shift between gears is not such a good thing. So, we're gonna get the electrical repaired first and then see how it affects the tranny. At least I'll be able to get the truck smogged and re-registered.
Oh...the bad new: $1307 plus tax..........so far. It makes me appreciate my '96 even more.
04-09-2012, 02:02 PM | #20 | ||
the PCM connectors and under fuse box connectors are what I believe to be the problem. |
05-01-2012, 06:38 PM | #21 | |
I finally took the sub to get smogged today. Thank God it passed. Another stupidly expensive GM failure that shouldn't have happened or been that hard to track down.
I think my tranny shifts a little soft, though. A little too much lag between gears. I'll have that looked at by someone else.
