| Latest | 0 Rplys |
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
09-01-2006, 09:29 PM | #16 | ||
Re: Amp Fuse Keeps Blowin
09-01-2006, 11:30 PM | #17 | |
Audio Guy
what is bridged to what ...... I really have no idea how you have it connected together.
Here's the deal, an amp blows fuses because it is drawing too much current (power) from the battery. SO you have some choices 1) there is a short in the power wire - not likely since it works on the other amp 2) the amp is messed up some how 3) the speaker load is wrong for that amp - even though it is ok for the other one, not all amps can handle low impedance loads. |
09-02-2006, 12:07 PM | #18 | |
Paul the specs for those subs say that they are hooked up for an 8ohm load out of the box to a single connection. Im trying to figure out unless he used a different jack setup or just ran the wires from each sub right to the amp. They are 4 ohm so if each is bridged to its own channel it should be fine. And 8 ohms is sure as hell not low enough to draw to much current.
Unless he has an older 4ohm model like they used to sell at best buy and the subs are each 2ohm. Im aiming for short in a wire or that amp its self is bad. Cause pyle in general isnt very good. I cant even find an rms value for that amp. Ive seen 75x4@4ohm and 150x4@2ohm. And 200 @4 ohm bridged. And ive seen 400x4@4/2ohm. I know damn well thats not right.
Cant remember who posted it but if you see it give yourself credit Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota. Cardomain |
09-02-2006, 02:31 PM | #19 | |
Audio Guy
This one might be VERY difficult to troubleshoot over the net, but take maybe 20-30 min in person.
09-02-2006, 06:58 PM | #20 | |
I just think that the amp is a bad one. Also I am thinking of getting another amp, but definitely not from pyle.
Thanks for all of your suggestions, I tried everything and it was really helpful. Does anyone know any good amps that are at least 400 watts rms?? |
