Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 07-19-2012, 02:53 AM   #1
mhowe1182
87 blazer wont start
It turns over but wont start, i have changed the fuel pump, fuel filter, injectors, and i also put new connectors for the injector, and new plugs. But still will not start???? Any help would be great, thanks.
1999 k1500 350 hd tranny
8 inch lift
35" tires
mhowe1182 is offline   Reply With Quote
Old 07-19-2012, 08:19 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 87 blazer wont start
Check for good hot blue spark to all plugs.
Check and comfirm good fuel pressure.
Does it have injector pulse cranking?
MT
Old 07-23-2012, 06:04 PM   #3
mhowe1182
i have good pressure, and the spark was blueish white. I was told to change my ignition module. Could this be my problem??
8 inch lift
35" tires
Old 07-24-2012, 08:47 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
Not if you have good spark.
What was fuel presure reading?
SPARK AT ALL PLUGS?
Do you have injector pulse cranking?
MT
Old 07-24-2012, 09:16 AM   #5
mhowe1182
How do i check for the injector pulse??
8 inch lift
35" tires
Old 07-24-2012, 09:52 AM   #6
MT-2500
AF - Advisor
MT-2500's Avatar
Injector noid light tester.
Your local parts place should have one.
Also make sure you have 12 volts to positive side of injector.
If not.
The injector fuse may be blowed.!!!!!!
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
mhowe1182 (07-24-2012)
Old 07-24-2012, 07:27 PM   #7
mhowe1182
I checked all those things and they were fine, i took the fuel off and had someone turn the key on and i wasnt getting any gas out of it, i have put a new pump in like two weeks ago and a new filter.
8 inch lift
35" tires
Old 07-25-2012, 01:20 AM   #8
MT-2500
AF - Advisor
MT-2500's Avatar
Checking for fuel/pressure should be done with a fuel pressure gauge.
Just turning key on is not a good fuel pressure test.
Just.
Key on only gives the fuel pump a 2 second prime up.
May not be enough time to build up proper pressure
You need to check for fuel pump running and for proper pressure with engine cranking.
Does it run on engine cranking and what is fuel pressure?
MT
mhowe1182 (07-25-2012)
Old 07-25-2012, 01:25 AM   #9
mhowe1182
I think i might gotten the pump with low psi, i was looking at it and it says 12psi and i think i need 60 psi, so i will check the pressure tomorrow, and get back to ya..
8 inch lift
35" tires
