Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 04-17-2011, 06:43 AM   #1
S10SNODOG
S10SNODOG's Avatar
Rear end Front seal Leaking/ I think water Is getting in
2003 Chevy s 10 4 wheel drive V 6 vortec motor I believe the Rear end is leaking From the fronte Yoke seal how big a job to fix it I think you got that way from the driveshaft having e a slight vibration PLEASE HELP THANK YOU
S10SNODOG is offline   Reply With Quote
Old 04-18-2011, 02:20 PM   #2
S10SNODOG
S10SNODOG's Avatar
Re: Rear end Front seal Leaking/ I think water Is getting in
When I pulled the drain plug out A muddy oily reddish color contaminated oil came out it does have a small week
Old 04-18-2011, 03:03 PM   #3
inafogg
not a bad job,mark the driveshaft to yoke & yoke to diff so they go back
in the same position.
remove drive shaft,remove mounting nut,remove yoke by hitting w/brass hammer.
you can tap the edge of seal to remove it.
NOTE:check torque on mounting nut(yoke) before removal,so that the proper
preload pressure is applied on reinstallation
they do show 2 special tools,1 for holding rear from turning,1 for seal installation.not sure if they are really needed
Good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is offline   Reply With Quote
The Following User Says Thank You to inafogg For This Useful Post:
S10SNODOG (04-19-2011)
Old 04-19-2011, 05:43 PM   #4
S10SNODOG
S10SNODOG's Avatar
What size is the ring gear is it 8.5 or 8.625. And if it 7.5 it's a completely different seal????? CORRECT
Old 04-19-2011, 09:30 PM   #5
inafogg
parts store will have that info.what i see is the 7.5 & 8 inch are the same
part #.for a 03 blazer 4.3L 4 wh drive
Good luck
Live For Today
Yesterday is gone,
S10SNODOG (04-20-2011)
Old 04-20-2011, 01:58 PM   #6
S10SNODOG
S10SNODOG's Avatar
The big nut thats Behind the knuckle Is that pressed on at all 8 threads regular or Reverse thread
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 12:29 PM
97 Dodge ram 1500 4x4 Front axlel leak drugaria Ram Pickup | Ram SRT10 2 11-12-2009 05:17 PM
95 Camry Front Seal Leak JennyDee Camry/Camry Hybrid/Vista 1 05-01-2005 09:49 AM
88 GMC rear end pinion seal rayzanesheia Sierra 1 12-02-2004 11:16 AM
front seal leak gungadin Metro 1 05-23-2004 11:14 AM
