Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 12-13-2003, 07:06 AM   #1
thenrix
No Dash and parking lights 96 Lumina
I've got a 96 lumina and for some reason the instrument and parking lights don't come on. The radio doesn't dim either (don't know if this is connected) If the light sensor fails (or is removed) would this automatically dim all the lights?
thenrix is offline   Reply With Quote
Old 12-14-2003, 10:56 AM   #2
The Burning Rom
Send a message via AIM to The Burning Rom Send a message via MSN to The Burning Rom Send a message via Yahoo to The Burning Rom
Re: No Dash and parking lights 96 Lumina
They don't come on automatically or with the switch?
www.wicgp.com <- Wisconsin Grand Prix Club
1999 Black Grand Prix GT Coupe
1990 Red ASC/Mclaren Grand Prix Turbo Coupe
1990 Metallic Blue & Silver Grand Prix LE Coupe
1979 Blue Dodge Ramcharger
The Burning Rom is offline   Reply With Quote
Old 12-14-2003, 11:10 AM   #3
Bruticus
Bruticus's Avatar
Send a message via AIM to Bruticus
Isnt there a switch to dim the lights next to the headlight switch have u tried that ?
Bruticus is offline   Reply With Quote
Old 12-18-2003, 08:30 AM   #4
thenrix
Unhappy
The headlights come on but not the tail lights or instrument panel. I tried changing the headlamp/dimmer switch but thats not the problem. The only other thing I can figure is the daytime running lights module. But why would the tail lights not come on when I turn on the head lights?
Old 01-15-2004, 04:25 PM   #5
user225937
I have the same problem. I changed the headlight switch but it had no effect. The headlights and taillights are not on the same circuit. Tail lights are on the same circuit as the park lights and side marker lights. I found a fuse for taillights in the right side Instrument panel fuse compartment and a fuse for park lights in the left hand engine compartment fuse block. Both were good. Now I am checking into day time running lights.
user225937 is offline   Reply With Quote
Old 02-20-2004, 09:26 PM   #6
mike7330
I have the same problem now too. No tail/parking lights, side markers, dash lights, and the chime for when the door is open and lights left on do not work. I checked the headlamp switch, seems to be in perfect condition. I am gonna trace the wires if posible, see what they go to, and check into the daytime running module. Has to be a problem here somewhere. If anyone found the problem, please post it! Thanks!
mike7330 is offline   Reply With Quote
Old 02-23-2004, 12:03 PM   #7
mike7330
I went to one repair shop. (to get a replacment headlight, and hood, caused by crash) They changed switch, but still no dash lights. They said to check under the carpet around the doors. Wires could be corroded. Going into a different place tomorrow to get it checked and repaired. Will post problem!
Old 02-24-2004, 04:38 PM   #8
mike7330
Ok, the problem that I discovered, was corroded wires at the fuse. The engine compartment fuse panel on the driver side. Wires removed from panel and an inline fuse installed, corrected the problem. Only thing, you need to add a wire, or do the same for the horn to work, as it is on the same power wire.
Old 02-24-2004, 05:53 PM   #9
JERKY420
did anyone try seeing if there is power at the fuse or look for a bad fuse in the passenger compartment. It is known that a bad tail light fuse will shut off the side marker lights and dash lights as well.
JERKY420 is offline   Reply With Quote
Old 03-01-2004, 11:52 AM   #10
MinnesotaDJ
Weird, I had the exact same problem in my 92 Lumina, horn stopped working, figured I could do without horn, then one night, turned on the headlights...and nothing. Turned out to be corroded and broken wires in the drivers side underhood fuse block. 200 bucks to get it fixed. That was the problem with the horn too. There's only like 2 fuses in the box, one is a blade fuse for the horn, the other is a Maxi for the exterior lights. Both fuses looked good, but the problem was in the wires under their connectors.
MinnesotaDJ is offline   Reply With Quote
Old 03-04-2004, 02:25 PM   #11
giddy99
Talking OMIGOSH, my 1995 Lumina, TOO!
EEEK! Same things (no dash lights, then no taillights)! You guys are geniuses, and have hopefully saved me 100s of wasted trips to clueless mechanics! I'll post the results, when I find out.
giddy99 is offline   Reply With Quote
Old 04-03-2004, 10:14 AM   #12
tttrtn
Glad I found this Thread...I too had this problem....after searching all possibilities....I decided to search the net....well here i am....now I have my dash and tail lights back....for those of ou about to solve this same problem, be prepared to fix any other wires that have corroded in this fuse box.(drivers side)...seems like GM made a poorly designed fuse box, too much exposure to elements from bottom...I go now.....thanks to all
tttrtn is offline   Reply With Quote
Old 04-03-2004, 02:07 PM   #13
giddy99
Incidentally, approximately what did it cost you to have it fixed? I called a mechanic about mine, told him what I had learned on the Internet, and would you BELIEVE...?!?!? He got defensive and said that THAT didn't sound right, and he would start with the headlamp switch (?). Good grief.
Old 04-03-2004, 06:31 PM   #14
tttrtn
Re: Re: No Dash and parking lights 96 Lumina
I did the actual work myself....it took approx. 1/2 an hour... i did the backyard approach for a tempory fix ......I cut the( prk lmp) wires to the fuse terminal.( you will have to remove whole box and work on it from underneath)...then attached female terminals, then hooked them together with a wide blade fuse...a little tape for a security and then tucked under the box i cut them from.....nice and hidden now.....cost about $1.00.....and 30 mins.......hope this helps....ps if a mechanic charges anything more than an hour labour( they do need to make livings too) he's overcharging......get your mechanic to look on underside of this fuse box (drivers side)...he'll believe then....good luck...
Old 05-25-2004, 08:59 AM   #15
Grymlot
Fixed it
I just fixed this problem with a friend of mine... After reading the posts in this forum, we new where to look first - Driver side fuse box in the engine
After figuring some wiring out, we came to the conclusion that a wire was MISSING! Under the park lamp fuse, there was only one wire, the other end of the fuse seemingly connected to nothing, no traces of any wire that used to be there either...
Anyways, after testing it, we installed a wire coming right from one side of the fuse to the power source bolt lookin thin that is also connected to right next to the driver side fusebox. Saved probably $100+ by installing ONE wire
Grymlot is offline   Reply With Quote
