Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-26-2005, 04:09 PM   #1
Jag91040
Panel light dimmer switch fix 1966 GC
Might be of some interest as this seems to be a common problem.
Same set up on a number of years so it should apply to several models/years.
If your panel dimmer slide switch is inoperable or intermittent try this:
Remove the switch module - need to take of the instrument cluster trim panel and loosen a few screw at the driver side bottom cover to allow access to the screws holding the module in.
Remove the module - one connector.
2 screws hold a white cover on the back over the circuit board - remove them for access to the back of the circuit card.
If you know anything about soldering you can see that most of the solder joint on this card are bad, lack of solder or just look cold.
Reheat all the joints and add a touch of solder to them and it should fix the problem. Make sure you have nice shiny joints.
Will probably clear up other problems associated with this module.
I suspect the problem is with the joints leading to the wiring harness but there are not many there so I did them all.
Hope this helps.
Jag91040 is offline   Reply With Quote
Old 05-27-2005, 06:32 AM   #2
SteveB05
SteveB05's Avatar
Re: Panel light dimmer switch fix 1966 GC
Good tip...I'll try it this weekend. Make the wife happy if it works
Steve
'98 JGC (ZJ) 5.2L, Aluminum Radiator w/Electric Fans, 4" Cowl Induction Hood Scoop, Custom High Flow Air Filter, Magnaflow Cat / Flowmaster Super 40 Exhaust, Engine Oil cooler w/ remote filter, In-roof 8" DVD, Profile 600 Watt Amp, Kenwood 6.75" 3-ways, NV242, 3.5" Lift, RS9000s, 31x10.50x15 ATs, Proline roof rack w/ spare tire mount and 4 Hella 550s.
SteveB05 is offline   Reply With Quote
