06-20-2004, 05:24 PM | #1 | |
Turbo in a SL?
I was wondering can an SL model take turbo
06-20-2004, 06:05 PM | #2 | |
blue + red light magnet
Re: Turbo in a SL?
Yes, quite a few people have done it. It does require a bit of fabrication if you are planning to take the twin turbos from a vr4 and put them in, as well you will need a few other parts from a vr4, so a donor car may be necessary. If you just plan to add a turbo kit, the answer is yes. Just realize it is a FWD car, so traction will be an issue with more power.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
06-20-2004, 09:03 PM | #3 | |
what he said
also in mind, you cant run nearly as much boost on an SL due to the compression ratio of the pistons
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
06-20-2004, 10:27 PM | #4 | |
With the higher compression of the SL one would only need low boost numbers such as 6-9 psi.....any higher u would be in danger of destroying your engine. Just my 2 cents
06-21-2004, 03:21 AM | #5 | |
boost
Out of the people who have put a turbo in an Sl what turbo kit did u use. how high have you turned up the boost safely. If anyone has it could you tell me your before and after times at the track.
06-21-2004, 11:35 PM | #6 | ||
Re: Turbo in a SL?
