Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 01-16-2008, 07:44 PM   #1
winlo408
2001 tacoma slight pull to right and left. any advice??
i have a 2001 tacoma, 4x2 pre-runner. early thing morning while driving around 60-65 mph i notice a slight pull to the left and right. The pull is very slight and once i correct it it'll be fine, then it will pull again couple seconds later. It happens very sudden, and it feels like a wandering motion, kind of hard to explain. Its not the feeling of losing control or anything but feels like you about to lose control for that one second. Kinda like if you got a flat tire. I know the brakes are low in the front because the sensor has been squealing for the past week (plan on changing after school on friday). can this be the problem? or something else? any advice would be great. thanks
winlo408 is offline   Reply With Quote
Old 01-17-2008, 05:25 AM   #2
Flash75
AF - Advisor
Re: 2001 tacoma slight pull to right and left. any advice??
Is the pull happening at a steady speed or is when you suddenly slow down or increase speed? Any unusual tire wear, front or rear? Check the rear spring u bolts for tightness and check the springs for a broken leaf. The brakes should be fixed but I don't think they are causing your problem.
Clifton
Flash75 is offline   Reply With Quote
Old 01-17-2008, 10:07 AM   #3
winlo408
its happening at a constant speed.
Old 01-17-2008, 03:55 PM   #4
winlo408
just checked the bolts and leaf springs and everything looked tight and in place. any other suggestions?
Old 01-18-2008, 08:16 PM   #5
fordtrucksonly
fordtrucksonly's Avatar
Hell, it could have just been the road..
But.. just in case
Check:
Tire pressure
Tire wear (crowning, cupping, etc...)
Bent or broken steering/ suspension parts
Oh and btw do you have oversized wheels or tires on it by chance?
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
fordtrucksonly is offline   Reply With Quote
Old 01-18-2008, 08:20 PM   #6
cannotoutrunme
Check those tie end rods for looseness slight ly bent mabe. had a old for that would pull like that fixed tie end rods ok.
cannotoutrunme is offline   Reply With Quote
Old 01-18-2008, 10:05 PM   #7
winlo408
i will check all this tomrrow with my buddy that works at a tire shop.
Old 01-18-2008, 10:58 PM   #8
cannotoutrunme
I hopeit will be itmy right was slighty bent.cheap to fix copared to other problems in front end. good luck
Old 01-24-2008, 06:05 PM   #9
Kyle4130
sounds like you already know the problem. your alignment could be off a bit as well.
Kyle4130 is offline   Reply With Quote
