Go Back   Automotive Forums .com Car Chat > Chevrolet > Equinox
Old 05-22-2015, 10:06 PM   #1
bsr2002
Question Engine Knocking
My engine started knocking the other day. The knock would speed up and slow down as I used the accelerator. We looked at it this afternoon took the top cover off and ruled out the rocker arms.
I found this YouTube vid with a Nox doing the same thing as mine. When I read thru the comments the OP had taken it to a mechanic and said it was the oil pump. What do ya'll think??
https://www.youtube.com/watch?v=CC--GnghHz8
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
bsr2002 is offline   Reply With Quote
Old 05-26-2015, 04:24 PM   #2
bsr2002
Re: Engine Knocking
This is my 2005 Equinox LS 3400
Oil pressure is good, even changed the oil to see if there was any metal in it. None. Any ideas as to what it is??
https://www.youtube.com/watch?v=nOx9746lPkY
Old 05-29-2015, 08:01 AM   #3
j cAT
Re: Engine Knocking
that is not a knock but a tick . tick like a lifter is bad or bad valve spring . sounds like one cylinder .
Old 05-29-2015, 07:56 PM   #4
Ruley73
Ruley73's Avatar
Re: Engine Knocking
I would also describe the sound as a tick more so than a knock. It could be a lifter, but I was thinking it might be an exhaust leak around one of the exhaust manifolds, and the ticking noise is being caused by the leaking exhaust gases hitting the heat shield. The fact that it goes away/gets quieter after it warms up is what makes me lean toward an exhaust leak. It's hard to determine the source of the noise in the video though.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Ruley73 is offline   Reply With Quote
