Crankcase pully removal 1.5L SOHCengbuster350 03-16-2008, 04:11 PM I've started to replace the timing belt on a 2001 Accent 1.5 L SOHC engine. I cannot remove the crank shaft outer pully. Is it pressed on (needing the use a a puller)? or should the nut be removed? If it is the nut that needs to be removed, is it a left hand or right hand thread? Any help appreciated. engbuster350 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
