Our Community is 662,000 Strong. Join Us.
View Full Version : Accent | Verna
Pages : [1] 2 3
  1. 2009 Hyundai Accent Belt
  2. 2002 Hyundai Accent Cranks but no start
  3. Accent Era Tuning
  4. 2001 hyndaui accen
  5. 01 accent codes
  6. 2008 accent power loss low rpm
  7. 01 Accent burned out check eng light
  8. Accent Oxygen/Fuel Sensor
  9. Looking for a 2010 accent gls bodykit (need help)
  10. 2012 Hyundai Accent Test Drive
  11. '01 Accent w/ RPM Fluctuation when Driving
  12. 2009 Hyundai Accent Gs Turbo Install
  13. Door Ajar light on all the time. Disappears when brakes used.
  14. p2188 2005 hyundai accent
  15. What's this noise? Power steering going bad? HELP :(
  16. Exhaust pipe diameter 1999 Accent
  17. Wheel bearing maybe trans?
  18. Check Engine Codes HELP PLEASE (im a girl on a budget :( )
  19. timing belt
  20. Car vibrates when accelerating...HELP!!!!
  21. Bucking
  22. Pulls to side when accellerating
  23. TPMS Light on
  24. 2011 Accent w Premium Package
  25. My 2003 Hyundai Accent GL died randomly while driving on the freeway... Why?
  26. Hyundai Accent Exteriors
  27. 2004 Accent - AIRBAG light on
  28. 02 accent ac problem
  29. 2002 hyundai accent wheel bearings
  30. 01 accent tranny fluid question
  31. '99 accent. getting engine light looking for evap cansiter
  32. 1997 Accent Tranny problem????
  33. Cylinder heads
  34. A question about the 2001 Accent
  35. What's the Overdrive for?
  36. Headlights burning out.
  37. Problem with my accent
  38. Ruptured fuel tank - dumb question
  39. Will check engine light always make you fail inspection?
  40. 2004 Hyundai Accent ( Drive Lights )
  41. Strange pulsating sensation in steering wheel...
  42. immobilizer bypass 08 Accent
  43. Transmission help and
  44. Spped Sensor
  45. Trouble gasing up!!!
  46. Nut size????
  47. 00' Accent wont revv past 3k
  48. Hard to get started
  49. Dim Headlight Problem
  50. Engine Stalls
  51. car won't start/sensor making buzzing noise
  52. 2007 Accent hatchback power door lock problems
  53. Accent transmission question....
  54. 00 accent ecm wiring
  55. Starting/stall Issue Since Changing Fuel Filter
  56. Free Hyundai Accent service manual
  57. 2001 Accent Transmission Oil Plug location
  58. Need help with wheel baring ?????
  59. I hate the Accent 95-99
  60. Accent 2003 4 th gear cylinoid location
  61. accent flooding
  62. 04 accent fuel filter location
  63. increasing power steering pressure
  64. disc brake overheating
  65. Hyundai Accent Parasitic Drain. Please Help.
  66. Changing front brake pads.....
  67. Question on 1996 Accent
  68. Can Anyone Find A Trunk Cover?
  69. 1999 Accent Sputtering
  70. Long to warm up
  71. Looking for a manuel
  72. (uk) accent 1.3LSi starting problems
  73. piston compression - accent coupe
  74. Burning oil.... but how???
  75. 2000 Hyundai accent console removal
  76. 2002 hyundai accent GS alternator
  77. cvvt setting on a accent 2006
  78. 2001 hyundai accent no acceleration
  79. '01 Accent dies while driving
  80. How can I replace the license plate bulb
  81. Accent Dies while driving
  82. How to change wheel barings??????
  83. Bad vibrations....???
  84. 2002 Hyundai Accent PO734
  85. Hesitation question....??????
  86. Hyundai Cars are Junk!!!
  87. no chime sound when I forget the light
  88. '00 Accent P1128
  89. brake work
  90. >>Vacuum hose problem???
  91. HYUNDAI cars are WORTHLESS!
  92. **'01 fuel filter Question ??????
  93. 00 accent auto trans
  94. 95-96 clutch problems/tranmission problem
  95. Test
  96. I need help with a problem
  97. Replacing the door handle
  98. 2008 Accent Radio Question
  99. Changing tranny fluid????
  100. power washed my engine, fried ECU -99 accent
  101. replacing radiator on '99 accent. Is it simple or complicated
  102. *2002 Accent Emission Codes Help Needed*
  103. sunpro 7906 tach installation 2000 accent 3 dr mt
  104. Someone please help
  105. Bake drum brake problem?????
  106. HYUNDAI ACCENT E coupe 1.3I 1999 brake problems
  107. Crankcase pully removal 1.5L SOHC
  108. Hyundai Accent 1.3i Coupe Ball Joint
  109. HYUNDAI ACCENT E coupe 1.3I 1999 T PLATE
  110. Hyundai Accent 1.3i Coupe 1999 T Plate
  111. Hyundai Accent 1.3i Coupe 1999 T Plate
  112. 99 accent trans question
  113. car overheating and no heat from heater
  114. 97Accent turnover but wont start,if pushstarted it will start, HELP!!!
  115. tranny interchanges
  116. Battery
  117. 97 accent tranny problem
  118. Horn not working
  119. 2002 accent wiring issues
  120. 1998 Hyundai accent low power consumption/car stereo shuts off when lights are on
  121. Accent starts sometimes, and wont turnover others???
  122. Timing belt replacement problem
  123. Timing belt replacement problem
  124. Timing belt replacement problem
  125. Timing belt replacement problem
  126. Timing belt replacement problem
  127. Timing belt replacement problem
  128. '98 hyundai accent check engine light
  129. exhaust questions.
  130. p1128 quandry
  131. hyndai accent 2004 radio replacement
  132. problem while filling fuel in the tank
  133. Can anyone offer assistance with my brake problems
  134. 97 Accent Rear Drums?
  135. Body Kit
  136. Sensor Location?????
  137. My wippers won't work!!!!
  138. Car Jerks at Red Lights
  139. Gas Gauge Not Working
  140. 2000 3dr towing possibility
  141. 2007 Accent mileage very low
  142. 2000 accent stalls
  143. Purge Valve Connector
  144. vibration?
  145. Diesel Accent
  146. Strange acting transmission
  147. 2000 Accent heater blower problem
  148. 2000 accent hard to start
  149. Need to prevent car from starting
  150. Blinkers
  151. 2004 Hyundai Accent Trans or wiring problem?
  152. fuel pump replacement
  153. Help!!
  154. Hyundia Mvi
  155. Stereo help!!!
  156. Fast car?....
  157. car jerks
  158. 2001 Accent-- Broken seal
  159. 1997 hyundai electrical problem
  160. 2007 Accent-No cruise control??
  161. Squeaky Spark Plugs??
  162. Shorted out door poppers???
  163. 2002 accent wet brakes
  164. 1996 accent wheel problems
  165. Thinking of buying a Hyundai Accent
  166. Interested in purchasing a 2001-2003 Accent....
  167. 01 Accent Hatch Light
  168. gas mileage sucks!!!
  169. won't start! help
  170. Avante Steering Problem
  171. aftermarket hood
  172. Question regarding the ECU on a 2002 Accent
  173. cfm question on a 2000 accent
  174. Freezing Transmission Problem
  175. front wheel bearing change
  176. gearlinkage cable help
  177. 2002 Accent
  178. Test connector location?
  179. 1997 Hyundai Accent
  180. Reverse Lights stay on
  181. Accent Instrument Panel Light
  182. 96 Accent HELP!!
  183. timing belt
  184. 02 accent help please!!!
  185. Dropping a 4G63T into a 2007 Accent
  186. Coolant Temperature Sensor
  187. ecu codes
  188. 2000 Accent dies after starting
  189. codes ?
  190. 01 accent will not shift into overdrive
  191. '95 Accent (General) Transmission Question
  192. Installing Transaxle in 2000 Hydundai
  193. 1998 hyundai accent gear/transmission problem.. *downsifted at 5 mph from 3rd to 1st"
  194. HOW DO I TEST IGNITION COILS 02 accent?
  195. 2002 Hyundai accent HELP!!!
  196. 96 accent missfire
  197. Help!!! Gas Pedal Is Resistant!
  198. suspension
  199. Questions about motor specs
  200. 2000 Accent transaxle gear oil change to Redline MTL & MT90
  201. 1996 Accent - low rpm hesitation
  202. 2001 Accent not going into Overdrive
  203. locked keys in car
  204. Anyone know were i can find Euro tail lights for my 2003 hyundai accent
  205. need hep fast 96 accent how many 02 sensors does it have?
  206. I need help really bad with a 2004 Accent
  207. Is it worth fixing and keeping?
  208. p0422 code
  209. 96 accent 3rd & 4gear GONE help 5speed
  210. 2002 Accent idle throttle problems help plz!!!
  211. Ruff Idle and loss of power
  212. Front Wheel Bearing
  213. 2002 Accent Wheel noise.
  214. smoking battery
  215. Got an Accent gave to me....
  216. Parts needed...need help to find
  217. Accent acceleration problem
  218. Been looking at another 95 Accent
  219. Is The Excel Sprint 2 Cars In 1 ?
  220. Exterior Handle
  221. O2 Sensor or what?
  222. 98 accent
  223. standard 2 gear
  224. Air??
  225. How good?
  226. 01' Hyundai Accent
  227. How much is a 95 Accent worth?
  228. 2000 accent code 1128 and 1123
  229. flex pipe problems
  230. accent codes P1529, P0740
  231. 1998 Accent Transmission Problems
  232. When they do an alignment, can they see other things wrong
  233. changing oil pan
  234. VIN decoding?
  235. 2002 Accent Right Front Window Regulator
  236. 2002 Accent P0444 code
  237. reverse lights not working
  238. battery ?
  239. Dash light doesnt work 96 accent
  240. Cheap easy turbo for an Accent? No BS
  241. 2002 Accent GS Wont start need help...
  242. 95 accent horn
  243. 96 Accent Headlight Low Beams are out
  244. Accent 01 Body Kits
  245. 96 accent smell gas on start up
  246. 96 accent.. sloppy stickshift and steering?
  247. i need quick fast help plsss
  248. 99 Accent Speed Sensor
  249. engine and ecu codes
  250. ruff idle? any ideas?
