99 explorer problems with climate control
nickobone
12-26-2007, 05:21 PM
1999 4.0L SOHC Sport
It was hit in the front end a while ago and right after that began the problem
It will only blow on the highest setting (Fastest Speed)
It will only blow on Defog
No other setting will work
Hot and Cold Knob works
Checked all the fuses
thanks for the help!
-nick
-nick
way2old
12-26-2007, 06:05 PM
Sounds like the blower resistor got damaged. if it only blows on high, usually the resistor is the problem.
nickobone
12-27-2007, 09:22 PM
not to be lazy or anything but where is the resistor located?
way2old
12-28-2007, 06:46 AM
Look under the hood on the AC plenum. Tou will see a connector with 4 or 5 wires going to it. This is the resistor.
