Our Community is 662,000 Strong. Join Us.
View Full Version : Explorer | Explorer Sport Trac
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. 1998 Explorer Eddie Baur w/auto climate
  2. 1994 Ford Explorer 4.0L
  3. 06' 120k-tranny flush vs. fluid change?
  4. 06' keypad code location?
  5. Sport Trac RV conversion
  6. Starting Problem
  7. Tires for 2002 XLS 4x4...
  8. Warm Heated Seats
  9. Ford Explorer
  10. 98 Explorer Eddie Baur 4x4 differential
  11. 2003 Sport Trac hesitation/jerking?
  12. Front Hub Removal Question
  13. 98 5.0 don't have cam sync tool
  14. Question on the Explorer Ecoboost 2011/12/13
  15. 2007 Ford Explorer Inside car light
  16. speedometer reading too high and too low
  17. 1992 Explorer 4.0
  18. flashing OD light
  19. 2000 Explorer changed IAC now have loping idle & hum
  20. Ford Explorer 2011
  21. IS SPARK supposed to be noticeable from the out side of a alternator looking in
  22. ford exploder
  23. Oil ran out on Explorer
  24. 2000 explorer ohv 4.0 trouble starting
  25. 1999 ford exolorer
  26. 2007 Explorer Grill
  27. 2007 explorer fog light
  28. 95 explorer problems
  29. Engine Surging
  30. 2000 Explorer horrible steering wheel shake
  31. 98 Explorer oil pressure
  32. Help about raplace struts
  33. 01 Explorer dies in reverse only!
  34. 02 Explorer 4.0 xlt Starting issues
  35. 94 ford explorer
  36. 04 explorer 4.0 l now 12 mpg city was 16
  37. No reverse on 2000 Exploder
  38. Explorer parked for 3 years
  39. '03 Explorer Speed Sensor?
  40. Torsion bar question
  41. 2003 Explorer noise from left rear fender well
  42. Strange rattle when stopped
  43. ABS Question
  44. 2001 Recall
  45. Thumping noise from rear a/c-heater
  46. All windows stopped working
  47. 1999 Ford Explorer 4.0L -need assistance on removing upper intake
  48. battery light on, steering wheel not turning???
  49. 1994 Explorer hiccups and strange noises
  50. 2002 eddie bauer edition Differential Pressure Feedback Electronic Sensor circuit High Voltage and door ajar light
  51. 96 explorer door question
  52. 2004 Explorer "banging noise"
  53. Front Pass. Side Brake Rubbing 2004 sport trac
  54. 2000 rpm at startup
  55. Ford Explorer leaf springs
  56. rear end clunk, normal for LS?
  57. Fuel pump & ABS light
  58. 1996 4.0 turns over but won't start
  59. 2002 Explorer rear liftgate window shattered
  60. 99 Exploer AWD 5.0 Wont turn Over
  61. Air Ride compressor interchangeable?
  62. 99 Explorer Timing Chain...help??
  63. po 401
  64. What brand and where should I purchase new rotors and brake pads for 03 Sport Trac?
  65. 1995 Explorer XLT Wiring Question
  66. 2002 sport trac Miss fire
  67. Heater issues 2003 Explorer 75k miles
  68. Ignition Lock removal
  69. new ac replacement problems
  70. 04 Explorer fuel gage stuck near full
  71. 96 Explorer with binding front wheel.
  72. accessory power staying on
  73. 2005 Power Seat wiring
  74. 97 explorer xlt
  75. rear abs sensor bolt rounded
  76. No high beams and ball joint question
  77. AC is not cold and is blowing cool air from one side
  78. engine swap
  79. Multiple Electrical Problems
  80. knock in top-end
  81. Sport Trac 2007 Floor Hook
  82. 95 explorer problem
  83. i searched, now i ask-trans slippage
  84. What rotors should I purchase?
  85. Running rough and white smoke
  86. 01 Explorer Sport Leaking
  87. 97 explorer unlevel
  88. 2010 explorer xlt mpg sucks
  89. 2006 Rear Hatch Door Actuator
  90. Sounds like an old mattress
  91. '94 Explorer 4.0ltr code 124?
  92. transmission problem
  93. Ford Explorer Self Acceleration/Braking Problem (help)
  94. Marker Lights stay on
  95. 2002 Explorer DRL (daytime running lights) pulsating
  96. 2000 ford explorer tran slip!!!
  97. 2001 Ford Explorer Seats
  98. 1996 Ford Explorer Making A Noise
  99. 2003 Sport Trac Bed Cover
  100. Engine wont shut off
  101. Abs
  102. 06' rear end issues
  103. Blown Freeze Plug
  104. 04 po193 fuel rail sensor
  105. fuel damper for 4.0x motor
  106. Rear Hatch???? cracked
  107. 2002 Explorer - Heat/AC Vent flapping
  108. 2002 explorer 4.0l, will die when turning from stop sometimes
  109. 2003 Ford Explorer Steering problems
  110. Electrical problems with a 96 Explorer XLT
  111. 98 v85.0 hard starting when cold
  112. A lesson learned
  113. running rough and getting bad smell from exhaust on 2000 ford explorer sport
  114. 2002 Ball Joints
  115. gas pedel repair
  116. belt ripping
  117. buying new car- what 2B replaced?
  118. explorer radiator
  119. help!
  120. 97 Explorer SOHC water pump
  121. Surge before engaging in drive
  122. 2002 Explorer lost reverse
  123. Why won't my car start?
  124. fuel pump stays on
  125. If you have cold and warm air blowing from defrost duct only this thread is for you!!!
  126. 2003 Ford Explorer Code P0430
  127. 2006 Explore won't take gas
  128. Wants to cut off when I stop at lights
  129. 2000 Explorer Sport Trac issues
  130. 1992 Ford Explorer Battery Problem
  131. looking at engine swap from 99-2001 4.0sohc
  132. 2001 explorer sport with no power.
  133. 92 Ford Explorer Head Gasket
  134. Keyless Entry Module Pinout Needed
  135. Rear freeze plug
  136. 2000 explorer rough idel at start up
  137. Transmission wont go into drive.
  138. 03 Explorer Defrost Problem
  139. 99 mountaineer 5.0 hard starting in cold
  140. 1994 Ford Explorer Hard starting after it sits.
  141. Explorer 2005 - Charging Problem
  142. 99 Explorer Trans "D" issue
  143. 1999 exployer problems 4.o sohc
  144. 97 Explorer Sport
  145. vaccum leak/intake
  146. 2002 Sport Trac
  147. 2008 Explorer
  148. 98 explorer power mirrors
  149. Brake Bleeding 99 explorer sport
  150. 2007 Explorer Eddie Bauer OD/Off Switch Sticking
  151. 95 Explorer XL 4x4 problem
  152. starter issue?
  153. 2000 Explorer XLS keyless entry
  154. Trans problem explorer
  155. 2000 Ford Explorer fuel problem
  156. Sudden Increase in Fuel Consumption
  157. Engine Performance problem
  158. 1996 Explorer with blower motor issues
  159. 94 Explorer code problems
  160. Starter or relay or other?
  161. 99 Explorer No Start
  162. 95 explorer 4x4 issue
  163. Ford explorer 2001 healight
  164. 04 Sport Trac Electrical Issues
  165. Electrical Demons?
  166. 1996 explorer trouble
  167. 2000 ford explore Misfire with NO CHECK LIGHT?
  168. Brake pedal goes to floor
  169. What is this cord used for? 1999 Ford Explorer?
  170. 98 Explorer has no power
  171. 2003 Explorer feels like driving over expansion joints on deceleration
  172. Code P0171
  173. ABS Kicking in when not in a slide
  174. O2 sensors wireing
  175. 2004 Explorer Vibration...
  176. 00 Explorer bucking at certain rpms
  177. Fuel Line Connectors at Fuel Filter Red and Green???
  178. 98 Explorer air/fuel ratio issue? HELP!
  179. replaced IAC valve, idles worse than ever
  180. Hoping someone could help with a Pop in my Tranny.
  181. HElp me im an idiot
  182. ftp sensor ford explorer location
  183. Car overheating
  184. 98 explorer AC compressor won't come on
  185. 1998 Explorer Driver's Side Upper Ball Joint Removal
  186. Rear spring shackles
  187. Double Din
  188. Explorer airbag
  189. 2003 Eddie Bauer Climate Control Cycling
  190. Starter difference 1st and 2nd production?
  191. Fuel Filter and Water Pump Replacement
  192. 99 OHV Plenum sensor
  193. 2000 Explorer XLS front suspension questions.
  194. Chance to buy an 04 Explorer 4.0 l w/40k mi
  195. odd problem new to me, '98 explorer sport
  196. Power windows 1990 exp
  197. Tow hook add on question
  198. 2002 engine head removal
  199. 03 Expl EB DriveTrain Windup Noise
  200. 93 starts in reverse?
  201. Explorer/Explorer Sport Trac
  202. 06' explorer trans. computer update?
  203. help with tranny on 97 explorer
  204. 2000 exp sport OHV mis-firing.
  205. Quick HELP! Engine revs up, shakes, and shuts off
  206. Ignition problem?
  207. Ford Explorer (Fuel Problem)?
  208. 03 Exp loud clanking on top of engine near firewall
  209. a/c compressor makes clicking noise
  210. Wiper arms
  211. 4R55E Front End Play Check Gauge Bar T93T-77003-AH
  212. Cruise Control Help
  213. 2002 sport trac
  214. got my a/c fixed, I think it still leaks.
  215. 2002 explorer, random no idle
  216. 03 Explorer Pass. Sun Visor Mount Replacement
  217. Explorer that wobbles
  218. 2003 explorer door ajar
  219. 4R55E tranny rebuild problem
  220. Sunroof Doesn't Move
  221. message center shows errors but none are present
  222. 99 Explorer electric totally gone !!??
  223. Wheel hub removal
  224. need help on a c clutch
  225. Wire set question
  226. Rear passenger wheel knocking....
  227. drivers power window does not work
  228. 92 Ford Explorer Wont Start
  229. 98 explorer with many problems, please help
  230. Replacing Door Handle
  231. 98 explorer has od light flashing
  232. Rear Turn Signals Flash Wrong
  233. Front Seat stuck forward
  234. Cylinder 7 mis fire??
  235. '98 explorer 5.0L P0133
  236. New Owner
  237. 93 Transmittion (4x4)
  238. 99 Explorer need to by pass key chip module PLEASE HELP!
  239. Over Head Console
  240. 2002 explorer won't shift past 1st
  241. Weird hum/whistle.
  242. power locks
  243. a/c leak
  244. '01 Sport Spark Plugs
  245. 98 Explorer high revs in gear and stalls in reverse
  246. 98 Explorer, I do not have coil springs?
  247. Gas Gauge Not Reading Properly
  248. Frustration
  249. 2007 cluster problem
  250. Explorer 2001 sport track sparks from distributor?
