Replacing a Passat battery?
PITT Fan
06-26-2007, 10:18 AM
My 2002 Passat is now over five years old and I still have the original battery. I would apprecaite help with two questions;
(1) How do I take off the engine panel to determine if the battery acid level is low?
(2) The dealer wants $78 to install a new battery. Is it necessary to go back to the dealer or can I simply have Sears install one of their international "Die Hards" for a $12.99 instllation fee. I realize the dealers are always more. However, I am concerend if any part of the computer system needs to be "rebooted" because of the electrical system being disconnected.
Thanks
Thanks
diesel_uk
07-24-2007, 03:09 AM
remove rubber trim around the plastic and "pull off" clips. Its very easy. To fit back its the reverse.
jsmith27
07-30-2007, 09:45 PM
You supposed to use a battery back up system when you chang e the battery in most passat's. it keeps the computer alive.
