Our Community is 662,000 Strong. Join Us.
View Full Version : '97+
Pages : [1] 2 3 4
  1. STOP! Oil Pressure warning light
  2. AC blows warm, I got 513, 4F7, 4F8, 4FA error codes
  3. 2012 VW Passat TDI Test Drive
  4. 2002 passat 1.8T front exhaust pipe
  5. How to find the infamous 5A hidden fuse only on automatics?
  6. Just replaced spark plugs
  7. 2006 passat with electrical problems?
  8. Passat 01 1.8L turbo check engine code P0118
  9. passat 01 1.8L turbo EPS light
  10. Passat 01 1.8L Tur low oil pressure light
  11. new to forum
  12. Accident - Hood replacement or Fix?
  13. 2001 VW Passat 2.8L
  14. dipstick broken
  15. 1999 passat surges and jumps into gear
  16. Thermostat problem?
  17. 2002 Passat 2.8 wont start and only hitting on one cylinder
  18. 99 VW Passat Daytime lights wont go off
  19. 2000 1.8T 120k vs. 03' V6 GLX Passat wagon?
  20. 99 1.8T won't start
  21. Climate Gauge and Dash Temp sudden change? What's wrong??
  22. '97 Passat ??s
  23. Need help with code P0300 P0301 and P0302
  24. CV / Driveaxle
  25. Passat estate automatic diesel 2003 ABS light on at 60 mph
  26. First ignition coils, now boot lid motor ...
  27. 02 Passat 1.8t hesitation problem
  28. 1999 GLS electrical problem
  29. Loud cooling fan 2005 Passat
  30. Delay then jerk acceleration
  31. 2000 passat no speedometer
  32. 1999 Passat 2.8 overheating on highway
  33. battery problems
  34. 2000 Passat 1.8T camshaft actuator
  35. Detailed question about 2004 Tranny prob.
  36. Detaied question about 2004 Tranny prob.
  37. please help leaking coolant....
  38. 03 vw passat GLX 2.8l V6 30V Won't start
  39. 2000 Passat having problems in low rpm
  40. 1999 passat timing belt lost teeth
  41. 2202 Passat Passanger side headlight
  42. 06 passat starts then stalls, and gas cap error
  43. Transmission problems after major service
  44. 2007 Passat wolfsburg - oil usage
  45. 97 pasat window regulator
  46. 1999 Passat - Changing Brake light
  47. Repair Manual for 2006, 2007, 2008... Passat?
  48. 2005 Passat
  49. 2003 Passat 1.8T Shaking and Pulling to Left
  50. shuts off
  51. 99 vw passat abs,brake,oil,ding noise
  52. Passat overhaul
  53. 2006 Passat, what should I know?
  54. how to change Turn signal, headlamp
  55. Anyone know how to delete a post?
  56. Belt Tensioner?!
  57. 99 Passat tiptronic shifter not working
  58. 1997 VW Passat Drive Belt Diagram
  59. Adjusting headlights on 2006 passat
  60. PDF Service Manual?
  61. Rim for 1999 passat
  62. Please help me car won't start!!!!!
  63. 1999 1.8T passat high rpms
  64. FASTEN SEATBELT Chime Disable
  65. wipers adjustment
  66. radiator and coolant question
  67. 2 1998 Passats B5 Variant in China: Pics
  68. Front Suspension Replaced 00 Passat
  69. Oil Pressure unit
  70. Water pump belt replacment
  71. 1999 VW Passat V6 2.8 overheating
  72. 2002 Passat code: P2096
  73. 99 V6 trany computer
  74. 2003 passat climate control issue
  75. Shaking steering wheel
  76. Question: 2003 with W8-sensor problem?
  77. emission workshop message
  78. looking for diagram for door window cable
  79. 1999 passat 2.8
  80. Tiptronic Help
  81. a/c recharge unsuccessful...what now
  82. 2000 passat hp gains
  83. 2001 Passat Instrument Cluster
  84. 05' Passat 2.5L inline 5 running rough HELP!
  85. 1997 passat radio problem
  86. 02 Passat 1.8t
  87. abs light on headlights turn off
  88. 1998 Passat Electrical Issues
  89. location of MAF on ATW 1.8T
  90. MAF sensor AUG/ATW vin?
  91. Need some advice on buying a 98 Passat
  92. limousime 1.9 TDI 1999 ventilator belt noise
  93. 99 Passat Radio Installation
  94. front and rear brakes
  95. 02 Passat 2.5 V6 TDI warning lights
  96. 2004 Passat Headlamp adjustment
  97. window problem
  98. 1999 volkswagen passat
  99. '00 Passat stalls/won't start
  100. 2004 TDI Passat Shudder on Acceleration
  101. ignition control module
  102. lots of wather in on passenger side carpet
  103. 02 Passat V6 4 Motion - - - low speed missing
  104. 2001 Motor Head needed
  105. PO118 - How Serious?
  106. Help
  107. Mass airflow sensor
  108. MAF rebuild?
  109. windshield wipers not working
  110. 2008 VW Passat 3.6 4motion
  111. 2002 Passat Oily water in intercooler
  112. Extreme Shaking and shuddering when hitting ~50 mph
  113. all gears selected/no tiptronic/no 5th gear
  114. 99 passat passanger window and lock
  115. Windshield Wipers Work but Store in Up Position
  116. Can ac pulley/clutch be replaced 99 passat
  117. 01 Passat no electrical at all
  118. 2002 Passat Timing belt
  119. ! inside triangle idiot light
  120. Replacing Head Lamp
  121. Windscreen And Side Wndows Mist Up Badly Help!!!
  122. No Heat or A/C
  123. 1
  124. Camshaft Alignment Tool 3391 & 3242
  125. P1128 Code Suggestions/Outter Door Handle Broken
  126. Help w/ changing the fuel filter on 99 Passat?
  127. Satelite radio out, warrenty past
  128. 2003 VW Passat Codes
  129. 2000 GLX 4Motion won't start
  130. Electrical problems; cruise, dash light, windshield wipers
  131. transmission problem
  132. alternator workshop?
  133. vibration problem
  134. Any help appreciated
  135. cooling problem
  136. which is better 1.8t, V6, w8?
  137. Why doesn't my cruise control work?
  138. Passat Door Locked
  139. Stereo Problems 99 Passat Glx
  140. Timing Belt Round 2
  141. Aux Colling Fan
  142. Tranny shifting problems
  143. 1999 passat no start
  144. 01 Passat Loud Humming Noise
  145. ABS/Brake Fault
  146. ABS/Brake Light , Fault 01200
  147. 2004 Passat Headlamp / Headlight Intermittent
  148. 97 Passat VR6 Secondary Air Injection Pump
  149. 99 Passat problems
  150. Fuse 13 and 14 keep blowing
  151. Info
  152. Emmissions Workshop, sound familiar?
  153. 97 Passat (b4)Transmission Mount (replace)
  154. 03 Passat Wagon Question(s)
  155. 1999 V6 Passat - stutters on accelleration
  156. 1999 V6 Passat - stutters on accelleration
  157. Passat oil issues again 2006
  158. 2006 Passat - Starting problems
  159. 98 passat 1.8 20v turbo
  160. 2003 Passat, 1.8L -bad engine, 125,000 Miles
  161. P0118 Fault Code Issues
  162. Too many issues.. Need a mechanic...
  163. Which OBD
  164. car won't start
  165. WTB - 99 Passat passenger side corner light
  166. Please Help!!
  167. 2007 volkswagen turbo-car keeps stalling
  168. Front turn signal light 2006 Passat
  169. Power Steering fluid.....
  170. Power Mirror issue
  171. 2001.5 VW Passat Mirror does not stop tilting up
  172. What's it worth?
  173. help w/04 passat headlights
  174. 1.8L Passat oil pan removal??
  175. passat scary drive
  176. 2001 Passat acceleration prob. (nub)
  177. 98 1.8 warm start problem
  178. Intermittent Brake Failure 01 Passat Estate
  179. Anyone know where I can find a w8 radiator online?
  180. 2002 VW passat GLX 4Motion
  181. Coolant light on
  182. headlights
  183. halfshaft replacement help???
  184. VW passat 2001.5 1.8T Cold start problem
  185. rear lights inop
  186. 02 Passat Hazard Flasher Clicks
  187. ABS control module 1998 vw passat gls 1.8L turbo
  188. Passat battery drain
  189. Considering 97 Passat 6cyl - Need Feedback
  190. Passat "Jolt" at crusing speeds?
  191. 02 Passat glove box
  192. Help in changing a bulb in A/C unit
  193. Vacuum sound on passenger side of engine
  194. Is there a difference between the air flow sensor and meter?
  195. Big problem plz help
  196. 2000 passat clutch fan wrench size
  197. Key/Lock problem
  198. 2000 Passat 2.8 no start/lock problem
  199. Anyone know the name for this piece
  200. Passat Alarm troubleshooting
  201. 99 Passat Passenger seat won't lock in position
  202. shudder and slipping tranny 99 passat
  203. 1999 passat problem
  204. Should I buy 2002 Passat W8
  205. 98 passat code 1136 and 0303
  206. frustrating diagnostic
  207. Onboard computer problems
  208. 99 passat break down on highway
  209. tiptronic bad
  210. Another Passat smell question
  211. 99 Passat, ran rough then wouldn't start
  212. Buying 2001.5 Passat GLX V6 - What to look for??
  213. electrical connector pin removal
  214. 2001 Passat. Check Engine Light
  215. No Power to AC- Steering Wheel controls, Stopped working while driving
  216. My trunk is heating up?
  217. 99 passat radio problems
  218. Passat Electronic Power Control (EPC) light
  219. 99 passat v6 - a/c not working - electrical???
  220. Slow or infrequent starting 98 Passat - HELP
  221. ac blows hot and cold air
  222. Strange radio behavior 2002 Passat
  223. Passat help
  224. POWER STEERING BELT TOO BIG HELP! 98 passat
  225. Turn signal turns off/won't work 2001 Passat
  226. Do 97 passat glx vr6's have sai?
  227. Vexing Electrical Problems - '02 Passat
  228. Passat SW 2001.5 Vacuum hoses
  229. Replacing a Passat battery?
  230. performance help
  231. 1999 Passat GLX 6 cyl.
  232. 1.8t sport passat 2001 mass air flow sensor problem
  233. code reader location
  234. 98 passat window regulator plastic piece
  235. 02 Passat - Passenger front/rear floor boards are wet!
  236. 02' Error code P0171
  237. Passat TDI
  238. Lower control arm
  239. 98 Passat random no start
  240. idling
  241. Oil pressure issue...Sludge, sensor or other?
  242. dump valve and boost gauge.....
  243. AC/Heater Fan dead except for fastest speed.
  244. Door lock problems
  245. 98 Passat 4cyl 1.8 not start Ple Help
  246. Turn signal, persistant clicking after signal is off
  247. 99 Passat Headlight Reminder
  248. Have a multifunction range switch for 99 1.8t if anyone is interested.
  249. how to fit a cam position sensor
  250. Thermostat housing
