programming keyless
pwh
10-09-2002, 07:34 AM
Can anybody provide details on how to program a keyless entry remote for a 2001 Mitsubishi Galant? Thanks. :frog:
barryc
11-28-2003, 10:57 AM
frog
did you ever get a response???
i have a 2002 and need to program the "clicker"
any help would be appreciated
barryc
frog
barryc
Blankman_J
11-30-2003, 12:16 AM
If you guys still need it, here's info from the servic manaul. It's detailed, but read it over a couple times then go through the steps and it should work for you...
BTW - the "Connector" refered to below is the OBD-II connector found under the driver dash, near the rear of the center console. Ignore reference to the "scan tool" - just ground pin 1 as indicated when programming.
A maximum of four different codes can be stored in the
EEPROM memory (four different transmitters can be used).
When the code for the first transmitter is registered, the
previously registered codes for all transmitters are cleared.
Therefore, if you are using four transmitters or are adding more
transmitters, the codes for all transmitters must be registered at
the same time.
1. Check that the doors lock normally when the key is used.
2. Insert the ignition key.
CAUTION: To prevent damage to scan tool MB991502, always turn the
ignition switch to "LOCK" (OFF) position before connecting or disconnecting scan tool MB991502.
3. Connect the scan tool to the data link connector. NOTE: If the scan
tool is not used, ground terminal (1) of the data link connector.
(This will connect terminal (1) of the data link
connector to ground, and the system will be in secret code
registration standby mode.)
4. Press the hazard switch six times within 10 seconds.
NOTE: At this time the code registration monitor request is
output (all doors locked and unlocked) and becomes
registration mode.
NOTE: The hazard warning light switch is turned on and off
alternately whenever it is pushed.
5. Press the transmitter switch, and then press it two times
within 10 seconds of the first press. This will register the
code.
6. When registration is completed, the code registration
monitor request is output (all doors locked and unlocked).
7. If you are using two or more transmitters or have added a
second transmitter, the same registration procedure should
be carried out within one minute after registering the code
for the first transmitter. After the second registration is
completed, the code registration monitor request is output
8. Registration mode will be canceled under the following
conditions:
• When the secret code for four transmitters has been
registered;
• When one minute has been passed after registration mode
started;
• When scan tool MB991502 is disconnected (the ground
connection is broken);
• When the key is removed from the key cylinder;
9. After the registration is completed, carry out the following
work, and then check that the keyless entry system operates
normally.
• Remove the ignition key.
• Close all of the doors.
Hope this helps.
J
the same time.
registration mode.
code.
conditions:
registered;
started;
normally.
Hope this helps.
J
barryc
11-30-2003, 06:07 PM
frog
barryc
Blankman J ----Thank you, but I could't get it to work. I don't understand "ground pin 1"!!!!! :banghead:
barryc
Blankman_J
11-30-2003, 06:23 PM
First - I assume you know what/where the OBD-II (J1962) connector is? Working off that assumption, to ground pin 1, simplly take a short lead of wire, strip one end and insert it in to pin 1 and connect the other to a local ground (car chassis). This puts the ECU in the learn mode for the remote code programming.
If you're not sure on the OBD-II connector, give a holler to your local dealer and ask them about the location - they should be able to help you find it.
J
J
Psionic-T
05-19-2004, 06:39 PM
Where is the OBD-II connector? Do I have to tear out the dash to get to it, or is it in the engine compartement or what? Does anybody have a picture of it?
Blankman_J
05-19-2004, 09:43 PM
No removing of anything. It's under the driver side dash, close to the center console/radio. If you look under there, you will see it.
J
J
Psionic-T
05-20-2004, 11:59 AM
Thank you. One more Q. .. how do you identify "pin 1"?
Inman Lanier
05-20-2004, 09:04 PM
Some other post identified pin 1 as the upper left pin when looking at the connector pins.
"pin 1 ... the one on the top row, far left, if you're looking at the connector with the wide part on the top) "
