Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mitsubishi
> Galant |
View Full Version :
Galant
Web
AF
Pages :
1
2
3
4
5
Hard Shifting
shaking around 40 mph on 1500rpm
99 galant timing
heater problem
1999 Won't Start
2000 Galant gtz ac last about 15min or less
No start - No Spark
Rear wheel noise........
02 galant turbo kit
Turns on and shuts off
HELP!!! 2002 Mits Galant OVERHEATING?!!
Very Poor Idle 2003 Galant 2.4L
Cost to replace Galant timing belt etc. .....
1997 Ganant service manual
2002 Galant wont start.......
Radiator Fan
96S Possible Trans. Issue? (Thin out the options)
95 galant wants new motor and dash
1973 gb lenses
Battery & Brake warning lights on
TCS lights
WTB 98 Galant but...
Radio code
Engine Code P0441 2002 Galant Where?
How do u change gear box oil galant gsr 89
Axle noise
STERO ( CD Player )
diagnostic code 43 1995 galant
rear end sliding
2002 galant es radio removal
Car covers and gauges
How do I change rear shocks on 1997 Galant
New Alternator and Battery - still runs the battery down!
Leaky ES
99 Mitsubishi galant
1997 Galant MAF question
2002 mitsh galant
94 Galant--any good?
it just wont stay on!!!!!!!!!!!!!
Oil Light on at idle
Multiply Problems.... need advice to fix.
air recirc?
'99 Galant GTZ slideshow
Gsx
Galant 2002 V6: DTC p0141 - Oxygen Sensor - Heater circuit malfunction
Pro-Start Remote Ignition Problem - 03 Galant V6
replacing an oxygen fuse? ...looking for an estimate
98 galant smoke problem
Alternator Removal: 2002 Galant
My 97' galant- navigation in Japanese
How much for A/C compressor and PS belt.
oil on spark plug
Honoring Veterans
99 galant head
01 Galant brake rotors won't come off
2002 Heat Problem HC Dial Control Blend Door
2003 Speaker Replacement help
Galant mpg?
mystery part in my mitsubishi
2002 galant stereo diagram
2000 Galant just purchased and has shaking
2001 2.4L A/C bypass belt
please help me!!!
my car shakes
OBD II port not working
Random misfires only when it warms up... why?
1991 Galant GTi Transmisson
galant 2000 radio code problem
2002 galant
Timing Issues......i think?
Photo's Or Plan View Of Alternator For 1991 Viento?
headlight burns out
95 galant radio code....
Reverse lights stuck on
Galant 1997 Gdi
Automatic Trunk Release 2.4 Galant 2004 DE
92 Galant AC trouble
1997 Mitsubishi galant
1994 Starting Problem....Hard start
2003 blower fan issues
1995 galant timing woes
97 radio issues
motor swap 95 galant
Am I Screwed?
03 Galant driver side rear window leak
I Need Help???
changeing the belts
fuseable link
2000 Galant Timing Belt
2000 Galant 2.4 SOHC - Bad/Low Idling
Fuel Problem
anyone know why my front tires is maken a noise
why i hear noises from my front right tire
1992 Galant GTI idling problem
e39a vr4 4g63t engine. HEEELLLPPP!!!!
questions
Need help 2003 galant v6 auto. no idle
galant 2004 swap
1991 Galant Ck Engine LT. How do you CK code what could it be?
Galant mmcs english CD translated
01 Galant 2.4L SOHC - Timing Marks help
timing belt problems
99 Galant Parts
Remove the trim for the stereo..02 Galant
Aftermarket stereo in a 02 galant
Need help with 2000 galant
no heater 2003 2.4 not thermostat
1997 Galant will not start
2001 Galant CD Player Issues...HELP!
Galant Ignition switch question?
galant diesel no start
ALDL pinout
Starting Problem..
1994 galant with overdrive/transmission issues
new alt & battery car will not run on its own
stereo locked please help
2001 Galant 6cyl starter - Help!
car will not start.
2000 galant will not start.
need help. overheating problem
fuelpump relay reset
ran out of gas now car won't start
ETAC Needed! Help!
Turn signals and hazard out help!
Buying a used Galant...
gear shifting help
Glant vr4 4g63 engine NEED HELP!
2000 galant injecter problems
Engine Coolant Drain Plug Location???
2000 Galant I think I have had it!!
89' Galant just dies on me in middle of road
95 Galant S Trans Filter location
Bleeding brakes tomorrow, 02 galant. HELP
02 2.4L SOHC Timing Belt replacement
Galant Project X
Burnout
94 Galant Radio and Clock won't work....
Galant 3.6 Spark plugs
bedliner in car
2002 Galant radiator problem???
door buzzer
99 galant
1996 Galant Horn Woes
shocks on 92 Galant
How To Set Basic Timing Galant 2003
1997 galant 2.4 fan inop
97 galant with overheating prob and oil light on
Engine Skipping
Another 2001 Mitsubishi Galant Leak
Weird Radio Problem '01 Galant HELP!
temperature gauge needle 03 galant
94 Galant - Tranny?
95 Galant Oil Question
1997 Galant engine replacement
e54 tuning advice
94 Galant wont start AT ALL
misfire 1st gear, '03 Galant
Shaking issues
1990 mitsubishi galant ECU wiring
2003 Galant - Service Engine Light On
1995 galant won't start.
help with aftermarket remote
2000 just died in the middle of the road?
Pros & Cons of Galant Diesel
Description of Galant Diesel
Mitsubishi Galant 2000 water in rug
Whats The Largest Rim Size I Can Put On A 1997 Galant?
2002 Galant Stereo
Problem with 2002 A/C
Transmission?
how do you install optix neon into fuse so that it turns on with the headlights?
00' Galant 4G63T
2002 stereo wiring diagram
2.4 GDI Idle problem
Time To Upgrade
WTB Nose Panel/Header Panel for 1994
squeaking noise
Looking for an 89 galant
Rear Hub Assembly
4g63 sohc to dohc
2001 Radio Code
Part Number
Can't Stop Brake Noice...Help
'03; Galant, a/c pulley not aligned..squealing
98 galant small/big problem
Help!!! Code P0302 01 Galant
'98 stereo input question
just purchased 02' Galant DE
92 galant overheating/no fans/burping sound in radiator
1992 Galant blowing A/T fuse
Need Help on 01 Galant Headlight Replacement
Turbo 7g galant
Need Help @002 Galant Starting Issues
Idle Air Control
Alternator??
Galant Dash & Tails Lights
1990 Galant VR4 white smoke from exhaust
A/C Switch 1997 ES
6 sets of 2 beeps, and ses light.
'97 Galant Sparkplugs, how to change?
Where can one get a lens for the headlight?
Tails Lights & Dash Lights Off & On???
1991 galant will not start
Synthetic Oil....
Cabin Air Purifier Filter R&R '03 Galant
94-98 galant parts for sale
how much for o2 sensor?
92' Rear Right Speaker Works About Half the Time
Shimmy in front end when accelerating...Help!
Galant transmission
Mitsubishi Galant 2003 transmission fluid
Galant Problem
need HELP! 2000 MITS GALANT RADIO "OFF" & wrong code.
Ford guy buying 1st foreign car, what should I know?
General Maintenance/repair Question, suspension
Galant 1997 Engine cranks slowly, but it wouldn't start!
90 Galant issues
transmission
2005 Timing
06 galant GTS gas mileage problems
2001 Galant oil light problem
Money Saving Question?
check engine light codes
99 Galant problem
Fuel gauge problems.
My 2001 Galant ES V6
Door trim assistance '92 galant
91' Galant VR-4 for SALE!
Galant Keyless Entry
2000 Galant Horn/keyless entry
interior:fake wood, need help!
1998 galant radio help please..
2006 Galant RPM.
Need help with changing the ATF.
Problem shifting into 1st
New 1995 Galant Owner
Communication CD
Fuel Pump Problem?
galant 2.5 v6 auto gear box
removing dash?
98 moon roof?
98 front end?
2003 Galant LOUD CLICKING!!!
1999 galant vrg
2003 Galant relays
2000 Galant Transmission
need help distiguishing galants
2003 Galant Engine Diagram
help needed
Temperature gauge goes wacky?
Web
AF
