How do you prime a fuel pump for a 2003 Kia Spectra?
blackknight7270
01-26-2007, 11:51 PM
Does anyone know how to prime a fuel pump for a 2003 Kia Spectra?:screwy:
welder3
01-27-2007, 12:49 AM
you dont prime new electric fuel pumps. you make sure they are submerged in gasoline and turn ignition swith on and listen to see if you can hear it. it should run for a few minutes and quit. when it shuts off that means fuel is at injectors ready for use now start engine.
blackknight7270
02-03-2007, 05:22 PM
I changed the fuel pump and the fuel filter and now the car wont start. Help!
blackknight7270
02-03-2007, 05:27 PM
The check engine light is also on and the car engine wont crank over. Maybe if I buy a code scanner and clear the codes. Will that work??????
welder3
02-04-2007, 11:01 AM
engine turning over is a separate issue than fuel pump. both starting and fuel pump are controlled by relays. and yes it would be advisable to get a scan tool to diagnose trouble code. you have an electrical problem by the sounds of it either a no connection issue, a relay issue or a ground issue or a combination of all of the above. hope this helps.
