Our Community is 705,000 Strong. Join Us.
Kia
> Spectra | Cerato | Forte | Mentor
View Full Version :
Need Parts for your Kia?
Car battery sometimes dies.
2001 Kia Spectra Turn signal problems
Aftermarket Cruise Control
2008 KIA Spectra- Front Parking Lamps Not Working
08 Kia Spectra manual transmission oil change
Shifting Rear End
Struts- Different brands on back ok?
2004 kia spectra
2008 Spectra SX front end noise
A/C Problems
Transmission Shift Issue
HELP!!!-One MOnth Later & My Car Still Won't Start!!!
2005 Spectra5 strange fast blinker/dash lights issue
Brake Bleeding
Look for some headers
2006 Kia Spectra Sx 2.0l starting problems
Gear Selector Problems
A/C pressure fluctuating
2007 Spectra fuel problem
Electrical problems with 2003 Kia Spectra
New Kia Incentives and Rebates – Dealer Negotiation Tricks Email
Front wheel noise on 2004 Spectra
2000 Kia Spectra fuel reset switch?
2002 KIA Spectra
What transmission
Dashboard
Transmission flush on a 2003 Spectra
Timing Belt on a 2003 Spectra
KIA Spectra Problems
Keyless Remote Programming
Shock/strut
2001 kia spectra transmission won't engage after the half shaft was replaced
Rattle and Slosh
High RPM at idle normal?
2002 Spectra heater and a/c Drain ???
Spectra Engine Problems after Wash
Location of throttle position sensor in a 2002 Kia Spectra
Smelling fuel inside car
2010 Kia Forte
Codes po422 and po460
Gauges stopped working on 2001 Kia Spectra
removing rear tail lights
03 Spectra with 78k jolting
Just picked up a new 08 Spectra5
02' Spectra Auto Trans Shifter replacement:HOW-TO
Spectra5 or Hyundai Elantra SE
2003 Spectra- Misfire on Cylinder 1
P1404 on a 2003 Kia Spectra
01 Spectra motor oil - which one?
Shaky 05 Spectra.
2009 Kia Spectra spy shots
2002 kia spectra
03 spectra leaking brake fluid
Aftermarket A/C
FS: 05-Current Kia Spectra Strut bar!
Very interesting KIA trivia.
Rattling Noise
'03 Kia Sprectra Code P0325 - knock Sensor mal
05 airbags
Wierd PS fluid and Tranny fluid.
2004 Spectra rear brakes
Sloshing noise
2001 Spectra clutch repacement
PCV HELP? 02 Spectra
Help! Oil on Spark Plug!
Fuel Tank access
windshield wipers wont work...2003 specta
oil
Spectra V. rio
'06 Spectra5 wiper problems
03 kia spectra
How do you prime a fuel pump for a 2003 Kia Spectra?
Rear Wiper Blade
03 Kia Spectra CD Player help
Towing capacity for 2002 Spectra GS?
2003 Spectra Help
What is the optimal tire size for 01 5door spectra
AM/FM Cassette Audio Adjustments?
Oil wrench size
Help Timing Belt
A/C complete meltdown
emission issue and drive cycle
3rd brake light
Best place for Aftermarket parts?
Replacing tailight bulbs on a 2001 Spectra
Spectra brake pads
V4?
rear brake going bad
rear calipers
Spectra Modifications
2004.5 Kia Sepctra Keyless Entry
High RPM issues
literally frozen ignition
My heat doesnt work
Help
Kia body parts
Automatic Shift Problem
Turn signal question - 01 Spectra
Navigation
2003 Kia Spectra Check Engine light
Kia Spectra Maintanence
2003 Kia Spectra Radio help
2002 Spectral Problems or Not?
Ark Performance - Looking For Spectra5 2005 for exhaust test fit
help
remote keyless sensor
Make it shift?
2002 Kia Raido Codes
Prostart remote starter
bad sensor?
spectra timing
Changing the radio station on a 2002 kia spectra
need assistance
Check out this new Specta5 - .
Who knew a kia could sound like this!
hmm
new here
Interested in a Kia Spectra
Kia misfire in Cylinder 1
2005 Spectra
New headlights
new board
Prostart Car Starter
change the spark plugs
I have had great luck with my Spectra
Thinking of a Spectra ...
Kia Spectra Jackson Racing Project Spectral K
Spectra Owners Group
2000 Kia Spectra GSX
Automotive Network, Inc., Copyright ©2013
