90 Probe 5spd CV Drivers side
jmanofktown
02-28-2006, 08:04 PM
Really bad grinding on front drivers side wheel. What do I look for after tire's removed and what should I do. I'm currently on low income due to disability and my extende medical doesn't pay out of the ass.
Thanks
Thanks
dajerm119
03-28-2006, 09:00 PM
if it is grinding then it might be the hub bearing. if it is a clicking noise then it might be a cv joint problem,especialy if it clicks during turns.let me know what sound it makes for shure and ill see if i can help fix the problem.
jmanofktown
03-29-2006, 07:23 AM
It was the wheel bearing and grounded down hub not mention bad boot on lower control arm. No problem getting same AIO parts mention at PnP. $60 and now I am a little stuck on getting the sway bar control linkage?? off without breaking.
dajerm119
03-29-2006, 06:17 PM
yea thats a tough one but just give her a little liquid wrench and let soak then try to break it loose. good luck.
jmanofktown
03-29-2006, 07:57 PM
$21.00 for two linkages. Frigging bolt cost more than what I got the wheel bearing for.
dajerm119
03-29-2006, 10:47 PM
that is prety steep but look at the up side when my wheel bearing went out i went to get it pressed out and the new one in and the guy told me he put 10 tons of pressure on it with a hydralic press and it did not budge. finaly he put some heat on it and it came out but any way it cost me 45 bucks to do that plus the bearing. and now im in the process of rebuilding my motor but i cant find any high performance valves. this sucks to but at least its not you. let me know how it goes.
C. Cleve
03-30-2006, 05:38 AM
Hi, Doing repairs on any car is a challange, BUT on a scale of 1 to 10. A probe is about an 8, GOOD LUCK and I hope you love your probe....Clay..
jmanofktown
03-30-2006, 04:18 PM
Well any vehicle is a luxury. We could still be travelling by horses. Vehicles are basically our adaption to the lifestyle we are brought into. We are told to be lazy and at any cost. Whether or not car's are good for the enviroment; it's only getting better. I love vehicles for the convience factor, but at the same time I understand that there needs to be a change in our operations of "the regular transportation.". Simply not enough fossil fuels. Totally off topic...All appologies. NO Money hurts us all.
