Our Community is 662,000 Strong. Join Us.
View Full Version : Probe
Pages : [1] 2 3 4 5 6
  1. A/C Compressor Will not engage...Pls Help
  2. 94 Probe - Reverse, Backup Lights Not Working
  3. Ford Probe A/C Diagrams
  4. 94 Probe Thermostat Location/Issues
  5. Trunk/Hatchback Will Not Stay Open
  6. What is it called?..... Help
  7. 1994 Ford Probe Timing Belt Concerns
  8. Auto Trans shift problems
  9. great
  10. idle help
  11. 1993 Ford Probe O/D light flashing with Fuel Cutout light on?
  12. 1995 probe wont idle
  13. 89 Probe start then stall after 2 seconds ?
  14. Wheel nut lock key?
  15. 96 probe no spark no gas
  16. clutch much?
  17. major swap!
  18. swapping 2.2l turbo into mustang
  19. Alternator Connector
  20. Loss of power and raddling. 1997 Probe
  21. removing the clutch master cylinder
  22. 94 probe gt clutch problems
  23. 93 factory rims for sale
  24. Probe won't start
  25. Turned crankshaft while timing belt was off HELP
  26. popping ?
  27. 92 probe head gasket
  28. 1990 Ford Probe Windshield Wipers Stuck Vertical
  29. power window change over
  30. 1994 probe window issues
  31. 89 Ford Probe Stalls
  32. probe stuck in 2nd gear
  33. 1997 probe gt electrical problem
  34. 89 ford probe valve lash
  35. Clutch Master Cylinder
  36. Radio help PLEASE!!
  37. Won't Start... help.
  38. High Pitch beeping noise
  39. Ford probe trans problem
  40. 95 Probe GT Headlight Stuck up
  41. Car Troubles - Idle Speed Variations
  42. 1989 Ford Probe LX
  43. vehicle speed sensor
  44. swapping V6 for my I4
  45. 1994 probe 2.0 i4
  46. 93 probe auto tranny shifting problems
  47. 93 I4 2.0 wont start!!!Please Help!!!
  48. white exhaust valves
  49. EGR Valve
  50. Starting Issues
  51. 1989 Ford Probe Reverse lights stay on
  52. Airbag code 33
  53. ford probe with 2.5L V6 burning coils!!
  54. ford probe swap
  55. Another distributor question
  56. 1993 Ford Probe, no spark from distributor
  57. Probe stuck on defrost
  58. 1989 Ford Probe rear hub retaining nut removal
  59. 89 Probe rear drum removal
  60. Ford Probe 1992 2,2 turbo
  61. Electrical Failure!!!! HELP!
  62. transmission
  63. Tranny ?
  64. Need help with a new clutch issue
  65. No overdrive-Only one gear
  66. Probe GT has no spark
  67. 97 Probe clutch problem
  68. Does anyone know how to set timing?
  69. 89 probe gt turbo TURBO LEAKAGE
  70. 89 probe problems
  71. 93 probe gt
  72. 1993 probe GT-key broke off in ignition
  73. 96 probe 2.0 hard starting
  74. cv halfaxle assembly
  75. 96 4 cylinder studder
  76. 95 4 cyl probe
  77. 1997 2.0 What PSI should my compression be?
  78. 93 Ford Probe transmission
  79. 95 SE car wont go in to gear
  80. shift cable 1992 probe
  81. finding shift cable 1992 probe
  82. Brakes Went Out
  83. 94 probe-power lost
  84. 92 probe lx 3.0 engine
  85. Odd 1993 codes
  86. 89 ford probe
  87. Fuel pump fuse question
  88. 1996 ford probe gt wont idle
  89. Mazda in probe
  90. 95 4cyl 5spd probe
  91. 89 probe, No power to fuel pump.
  92. 1993 probe gt v6
  93. 1993 probe gt v6
  94. engine/tranny swap
  95. rad fan not working
  96. Gaskets?
  97. Oxygen Sensors
  98. 95 4cyl. probe
  99. 1997 GT thermostat
  100. 1997 GT thermostat
  101. right hand drive
  102. Spark Plugs
  103. Pre catalytic converter replacement
  104. Factory tire pressure?
  105. Where can I find these SPlug Wires?
  106. My two headaches with my Probe SE
  107. 94 Probe GT with AT shift problems
  108. Probe Brake Overhaul
  109. what would be your reaction
  110. 93 probe gt transmission problem
  111. oil leak 1993 ford probe 2.5l gt NO turbo
  112. Airbag Warning
  113. Klze Swap
  114. Rear Wheel Drive Converstion Kit??
  115. '94 probe GT... Good or bad idea
  116. back fire
  117. Extreme Oil Leak
  118. 94 Probe transmission
  119. Engine cut off only whene I wait at red light
  120. my probey's better than yours
  121. Brake Lockup on 97 Probe GT
  122. starting
  123. 1993 Probe Trans/clutch problem
  124. 95 probe gt stumbling and running odd
  125. Clutch issue NEED SOME HELP :P
  126. riddle me this...
  127. pointers on my lx
  128. how to adjust clutch cable?
  129. replacing cv's
  130. 1993 probe water pump
  131. 95 SE 4 Clylinder loosing power please help
  132. 1993 Probe SE headlights do not work!
  133. '90 Probe headlight door won't open
  134. 1996 Probe clutch Tranny issue?
  135. 92 probe
  136. 97 probe no crank. where to start?
  137. Thermostat?
  138. Overheating Problem
  139. mass airflow sensor... yet another question
  140. Clutch replacement
  141. 93 ford probe GT Acceleration issue
  142. Motor Swappin'?
  143. upgrading exhaust system
  144. 93 gt poor idle when hot and hard on gas
  145. HELP... Idle issues now wont go anywhere
  146. 90 Probe Rear Window Defroster
  147. 89 thru 92 parts F/S
  148. 97 Probe won't down shift from 4th to 3rd
  149. no blower
  150. EGR malfunction
  151. problem probe
  152. need 89 probe help
  153. Lookin into buying a 1994 PGT
  154. 93 Probe 4cyl ATX vibration???
  155. Tripminder
  156. Turboing a KL-ZE
  157. 97 prope gt distributor
  158. probe is really starting to piss me off@!$%@
  159. 91 Probe GL 2.2 Idle Crazy Problems
  160. 95 pgt help please
  161. rough idle on 93'
  162. looking for a bov
  163. beginner mods?
  164. Help!!
  165. 1993 Ford Probe parts For Sale
  166. 93 probe se NO SPARK
  167. 1995 Probe GT NEED HELP
  168. Looking at a '91 Probe
  169. 94 Probe GT for sale $1,500 in GA
  170. shifting
  171. Key Problem... Please Help.
  172. 1992 v6 stalls, need help
  173. 93 gt wont start
  174. parting out a 93 ford probe 2.5 v6
  175. 96 Probe GT fuel problem
  176. 90 probe lx speed sensor
  177. Wheels & tires.
  178. Oil Pan
  179. rebuilt KLZE wont hold compression in cyl#4
  180. Tranny modulator valve???
  181. 95 probe gt temp guage stuck
  182. lProbe CD player problem
  183. 1993 need help!
  184. Rough Idle problem.
  185. possible electrical issue....
  186. Which turbo's can I put in my '89 Probe
  187. new tranny
  188. Advice on Pos battery cable terminal.
  189. another trans issue..
  190. Need Tranny
  191. 96 4cyl probe injectors....what size?
  192. A tranny problem or something else.
  193. Help headlight issues
  194. Help Asap?!?
  195. when to shift
  196. 93 Probe SE Starting Issue
  197. probe
  198. Klze?
  199. how fast is a probe
  200. 92 probe auto stalls when put in drive
  201. probe vibrating
  202. shifting and ignition
  203. Klze Wont Hold An Idle
  204. same problem - new info
  205. 1997 Probe 2.0L DOHC
  206. 93 Probe won't start... fuel
  207. 1990 probe automatic tranny problems
  208. probe
  209. New Probe
  210. OD light / tranny problem?
  211. 1995 probe
  212. Stick Shift Moves To Much
  213. 93 Probe parts or parts car available
  214. probe motor into escort gt
  215. Fly90mph
  216. any suggestions?
  217. Need help removing factory stereo
  218. clutch kit
  219. Moving soon, please buy my Probe GT parts
  220. $600 94 PGT Indiana
  221. 1990 ford probe modifications
  222. 1994 Ford probe GT KL-ZE for sale.
  223. Is probe a good first manual car?
  224. help me!! need torque specs
  225. KLZE Engine swap questions
  226. o/d light flashing
  227. trunk space
  228. Please Help/91 Probe GL
  229. Muffler problem
  230. aftermarket stereo
  231. Thermostat replacement
  232. My probe has no spark AT ALL
  233. 1994 Ford Probe - Full Car for parts. $600 Or Best Offer.
  234. Wont Start!!!!
  235. Alternator Question
  236. wont crank
  237. Idle issues
  238. vibration
  239. vibration
  240. error codes 90 probe gt
  241. will not run
  242. turbo manifold?
  243. gear shifting
  244. 1990 GT Gas tank Question
  245. 1990 Probe Tranny Problems
  246. Bad lifters?
  247. 93-97 Probe same as 98 Mazda 626???
  248. 89 probe rocker panels
  249. overheating,no powersteering and no heat
  250. Need help from ford tech's please.
