LOTS of oil in the spark plug !!!!!!! HELP
anusemoon
12-12-2005, 05:12 PM
i just bought a 98 catera with 48k on it... i checked everything possable on it before buying it.....
i opened the hood and took off the spark plug wire on the passenger side and it was full with oil.... i mean oil everywhere.... so i went to the driver side and pulled the #1 spark plug wire..... same thing.....
whats is going on... head gasket or what.... ( valve or cam cover) ????????????
need your help ASAP
need your help ASAP
anusemoon
12-12-2005, 05:30 PM
It could be the valve cover gaskets.... is it hard to change both sides???? how long will it take????does anyone know how much they run for the plugs ( what kind ) wires and both valve cover gaskets?????
diesel1962
12-12-2005, 05:48 PM
Hello! Is that a V-6 engine in that car?? What size is the engine?? Diesel1962
anusemoon
12-12-2005, 06:41 PM
3.0 v6..........
i called a local cadillac dealer and they are listing valve covers for $67 each !!!!!!! wow....
anyone know the steps of changing the valve cover gaskets?????
what to take off????
please help.... im going to start on it tomorrow....
Caddytech
12-20-2005, 07:56 PM
need your help ASAP
It would be the Cam covers leaking-It's alot of work to change the cam covers but can very easily be done-Just TIME!
need your help ASAP
yemboy
02-17-2006, 09:47 AM
Hi people look at me :banghead: . I don't have anything better then to buy a catera:banghead: which I thought was a steal judging by it's looks. I have the same problem it ended being my valve cover gaskets the parts alone for both sides is around $120. The labor is going to cost me around $400.00 gave it to a mechanic I know, he has it over a week because he opend it up and has been focusing on other cars in his shop. I wish I would have bought the repair manual and did it on a weekend even though I would have end up tearing half of the motor just to get to the valve cover gaskets, or maybe I should have taken it to a diffrent shop.or maybe I shouldn't have bought this stupid car in the first place and have had the couarge to get asain model instead of sorry opel with a caddy emblem. I hop that's the last problem I will encounter because my wallet is eeeeeeeemmmmmmppty.
by the way when I'm driving the lights in dashboard pop up once in a while and they go off for the radiator, check engine any help. Save yourself some pain don't buy a catera you will not find any mercy.:banghead: Help anyone out there plz.
Towman148
07-19-2008, 09:41 PM
Had the same problem with a 2000 cat that I picked up.....took some time but replaced the gaskets for the valves (did it twice actually because I listned to someone who said you don't need to use silicone on those)....not a hard job but takes some time as you have to rip most of the upper engine apart but it's workable....just make sure you have a good set of torx sockets and that you don't over tork the plastic valve covers and crack them (because you don't want to have to pay more than you have to fixing a catera) oh yea and make sure you hook up all the vaccume hoses you pull off too....good times
jdove1
09-26-2008, 10:31 AM
I OWN A 98' Catera and had the same problem and several mechanics told me that it was the valve cover gasket!:confused:
